[uk-vac] Bubble Bobble Sprite Glitches
I've started to get jailbars/glitches/cr*p on the player and enemy sprites but only when they're facing RIGHT for some reason. I've tried piggybacking the sprite ram, but that doesn't solve the problem :-(. Could it be the sprite buffers that are causing the problem, and if so, where are they located? From googling likely numbers, I am guessing that the offending part(s) may be a 74LS244 or 76LS375. Am I close, or waaaaaaaaaaaay out? BTW, it's an original Taito board.
TIA,
Christian.
TIA,
Christian.
