it's several days that I am trying to figure out why my spinner doesn't work properly with buggy challenge pcb.
the behavious is erratic, when you turn left of right, the buggy goes left or right in a random way and infact on the pcb test it shows the hex numbers going casually up and down.
using first a logic probe and then an oscilloscope I noticed that the inputs and outputs on the 74ls240 show a perfectly square waveform with a good histeresis.
the two outputs then go to the UP and DOWN pins of the first 74ls193 which is then chained to a second one via pins BORROW and CARRY to make an 8bit bus
here is the schematic
The outputs of the 2x 74LS193 shows some ramdom spikes between the squared waveforms which is , I believe the culprit of the problem.
I can also see on the logic probe the HI led turning on randomly between the waves
I would have already changed the ttls but to me it's really strange that both have the same problem....
I also tried to use a 14584 after the signals coming from the encoder PCB just to be sure I get a perfect squared waveform but the beheviour is even worse.
Any idea if I am missing something?
I don't have another buggy challenge to test unfortunately
