Buttons Not Working
11CR
Hi there,
Just got a Bombjack board
(bootleg as my original stopped working and was cheaper to replace than to repair for now
Problem is; the game powers up and displays but the board is not responding to any of my buttons.
I can short at the jamma harness to coin up (16 to ground) and start a game (17 to ground) but nothing from the buttons.
If I install a different game the buttons work fine.
Any ideas would be much appreciated
Many thanks,
Martyn.
Lurch666
21 (100%)
4,517CR
Have you tried starting a game then shorting the a control (say left) to ground to see if anything happens?
EDIT:Try cleaning the edge connector as it could be tarnished stopping some signals getting through.
Lurch6662021-09-09 20:49:16
11CR
Hi,
Yea, shorting I can jump and stuff. I am shorting the other pcb side of the connector so the signal is passing any tarnishing. Can't figure it out. Pushing the button on the control panel is just shorting anyway. Any recommendations on cleaning the connectors? Thet do seem worn (coppery). Could it be a voltage issue?
Thanks again.
bones
1,628CR
I think the inputs go to a couple of resistor networks,ra1,ra2 something like that before they get to the TTL chips, it's quite common that these can have broken pins at PCB level so worth a check there ,see if they're wiggly by gently touching them. Do try the above first though your button 0v may not be connected to the PCB 0v. Failing that I believe the inputs only go to a couple of cheapy chips as a worst case scenario.
Good luck, how much do the bootlegs roughly cost nowadays if you don't mind me asking, not seen one sold for a couple of years at least.
11CR
Hi, thanks,
Will try some of that.
Just thinking, I might try the JAMMA connector from my original board (god bless it, it's more jumper wires than pcb. Had a good life)
The Bootleg was €110 off Ebay delivered to Ireland from Greece (4 days!) . Tis in beautiful condition. I believe it's a one for one copy. Guy I got it off says buttons were working fine for him.
Thanks once again.
Martyn A Fagan2021-09-09 21:58:27
big10p
Coins detected in pocket!
6,092CR
So, the bootleg has the same pinout as the original? Do you have all the controls daisychained to the same ground? If so, check the ground connection is good.
Lurch666
21 (100%)
4,517CR
Maybe on your cab the GND for the buttons are connected to pins e,f,27 and 28 of the jamma connector.
If those pins aren't connected on your adapter the buttons don't have a connection to GND.
11CR
Finally got round to trying this.
Connected pins e to 27 and f to 28 of the jamma connector - nothing from the buttons.
Then troubleshooting connected pin 27 to 10 and hey presto the buttons are working.
Many thanks for your help.
Martyn A Fagan2021-09-18 17:53:01
