Buzzing Atari Transformers
aeroflott
A different league
16 (100%)
1,060CR
Several of my Atari cabs hum and buzz a little too loudly, and I've pinned it down to the large transformer block on the power bricks at the bottom of the cabs. Specifically, it's the vinyl wrap around the block that has come away, and the vinyl vibrates against the metal causing the buzz. When you clamp your hand around the plastic/vinyl coating, it's almost silent. Let go and they start to vibrate again.
I've got his issue with my Tempest, Asteroids and Missile Command.
So there's nothing wrong with the wring or anything, it's just this plastic stuff rattling away.
On my tempest, I've put a small bit of card between the vinyl and the metal which sort of resolves it, but inevitably, over time, it starts to move about and the rattling noise returns, so that's not a permanent fix.
What's the best solution for this? I was thinking some duct tape wrapped around the whole thing or a cable tie to tighten the vinyl back to the metal casing of the transformer itself, or some glue between the vinyl and metal, or just cut the vinyl wrapping away altogether?
Any thoughts?
obcd
3,830CR
2 component epoxy glue, or simply some building silicone might help to keep them quiet.
The first is very permanent. silicone is cheaper and maybe better to fill bigger gaps.
ColinD
6 (86%)
1,367CR
I believe it's the transformer lamination's that cause the noise (or possibly some loose windings), so you might see if you can nip up the bolts holding the thing together and giving the metalwork,windings a coat of electrical varnish (might prove tricky or impossible to reach all parts !!). Its all down to the magnetic field causing it all to vibrate.
