BZ Resetting
4,058CR
Anyone got any pointers where to start on this?
BattleZone - in test mode does all it's memory tests (which pass) then displays the cross hatch fine with the contrast lines in the middle, then resets.
In game mode you can hear vector chatter, that dissapears and then returns, it does this half a dozen or more times before eventually trying to display some text. The text shoots up diagonally from left to right. Not much else on screen when this happens.
Brassington kit in the board so ROMs all OK - don't know about Vector ROMs yet, not set up to test them yet after moving my repair room. 8 of the 10 rams on the board replaced and new sockets. Presumably the remaining two are fine as no bleeps in test mode.
Thoughts? Oh, all voltages ok!
4,058CR
P-Man said:
vector roms...
Cheers Andy. I've not touched this since posting as I've been busy on non arcade related things (building RC planes!) so when I go back to it, probably next week, or maybe the one after,I'll start with new vector ROMs and sockets...
4,058CR
I finally got off my arse and spent some time on this over the weekend as I'd really like to get the cab up and running now. In typical fashion the board was no longer doing anything remotely like I described above, the test mode was now all over the place and the game mode wouldn't do squat.
So I spent an hour or two finally sorting all my test kit out and plumbing the 9100 back up, long story short, vector roms were fine
After a bit of prodding about I found that the DVY12 signal was being held in a mid logic state and that definitely tied in with what I was seeing as it didn't look to me like there was any top to bottom movement going on. It looked like it was drawing right and left OK but up and down was down and down until it crashed in short order.
Tracing it through I arrived at B7 near the crystal - although actually very little, if anything to do with the crystal. On further inspection it looks like I'd bodged replacing this chip (yep, I guess it happens), there was a lifted track that I could see I'd placed back down as I soldered the chip in but comparing it to another board I'd connected it to the wrong pin. And guess what pin? DVY12 !
SO, I've sorted that out properly now and test mode comes up absolutely fine. I've got an 'L' so I'm going to need to do some signature analysis on the aux PCB, and in game mode it looks to me like the Window blanking is all over the shop (if I lift pin 13 of B7 I get a picture - if I leave it in, I don't).
Finally getting somewhere but man I hate BZ pcbs!
  • Like
Reactions: trm
