BZone PCBs
4,058CR
Guys,
What will a BZone PCB do if it a) doesn't have an aux pcb attached at all or b) the aux pcb doesn't work?
I've only worked on one once before and I seem to remember that it would come up in test mode with a duff aux pcb but not game mode? But I can't really remember.
I'm trying to get my set working. I've gone through and fixed a couple of bad RAMs, a 74LS157 and am using a BZ high score save kit to eliminate the ROMs but even with all the rams and roms testing out ok I'm still not getting any sense out of it.
Is there any kind of "snip pin X on chip Y" to get the game to run without the state machine like there is on Asteroids? or any other tips?
Thanks.
4,058CR
Ok, I can respond to myself now!
For troubleshooting purposes a BZ main board, in test mode will display the cross hatch pattern with a 'T' for timeout if the aux board isn't connected at all. Very handy indeed. Obviously that's assuming the AVG board is fully working, but it does mean that you can work on the AVG board as a normal single board until thats fully working, then progress onto the Aux board which as long as you use Signature Analysis, in my experience is easy peasy.
My BZ set is now coming along nicely.
I've replaced:
All program ROMs (these will be removed and the HS kit used instead)
5 x 2114
1 x 74LS157
Both DACs (bah!)
2 x DG201's (whatever they are)
2 x TL082
All 40 pin sockets on aux board (this was before I was sure if the aux board was having an impact).
And I now have a perfectly drawn picture but with retrace lines because /ZBLANK isn't working correctly. I also have an 'L' math box error when I connect the aux board.
This is a Duke Of Lancaster PCB so I hope it's not a sign of what's to come for all of the boards from the ship!!!
Martin.
andyman
1,059CR
Hehe, bit late on my PM but yeah, mine does that too
4,058CR
Hah! That'll serve me right. Last night I suddenly remembered that I had some repair logs on MY OWN site of all places. One of which is for BZ and quite clearly states that the AVG board will run happily without the Aux board.
Ho hum. That'll teach me
Shame it didn't help me with the other problems...
