Can anyone help
Shaun1905
71CR
Can anyone help I have a Williams Defender and a Sega Rally2 that won't work
the marque just lights up on the defender and the Sega just says looking for network
I am looking for someone that could come and fix them as I little to none knowledge on machines
Outrun2
Colonel Outrun
1,182CR
Sounds like your Sega Rally 2 is one half of a twin looking for the other linked machine. Is it a twin? If so, do both halves say the same? One half should be the Master controller and the other the slave machine. If it's a single you need to into the TEST menu and set it as a single in GAME ASSIGNMENTS.
To be honest you need to provide a little more information, have you ever had them working?
Shaun1905
71CR
Thanks for getting back to me, yes machine was working before it went in to storage, it is a twin machine and it says the same message on both machines
Shaun1905
71CR
I think so but I don't know much about arcade machines, was looking for someone to come and fix it really unless it was something very simple to explain and simple to fix
ZedEx48K
8-Bit
1,425CR
The optical cables are easy to check, they run along the connecting piece of metal at the back of the machines, then link to more going to the final destination, simple case of follow the wires.
Someone coming out is rare and likely costly.
Shaun1905
71CR
I have plugged all the cables in to each machine, I just dont know enough about them to play about with it, I don't mind paying for someone to come and fix it, I also have problems with a Williams multi game and a Williams Stargate defender Bothe marques light up but not much else
Do you know any engineers that live in the Kent area
Shaun
Nes4life
1,134CR
It’s not very common for people to come to you. Normally you need to do a little diagnosis and if it’s a PCB issue you can remove it and post it to a repairer and if there’s a monitor fault then you remove the chassis and post that. Someone like VectorGlow does PCBs (there are many other good repairers here). You could always ask if someone like RGP would collect your entire cab, fix it and then deliver it back.
gunblade
9,132CR
i doubt you will find anyone these days, it would cost you too much. I only know one tech who is even willing to do site visits and he is based in southend
I stopped on site repairs years ago due to people arguing about costs, I don't even visit arcades or companies anymore as no one wants to pay
Judder
1,009CR
Maybe ask Simon Den as he's vaguely in your area and might know someone local who can help
I'm 1 hour 20 away in West London otherwise I would help no problems with the Williams and Stargate / Multi machines you have
As the guys above say though, it might be easier just to remove the boards for the Williams machines and send them to someone to test
That's not a difficult job and you can read through my journey with my machine (now machines) below
The Sega Rally - no idea on that one though
Vamino
Insert coin(s)
2,700CR
With twin Model 3 drivers, as Gary has already mentioned, one has to be set to Master and another to slave in the service game assignment menu. To enter the service menu you need to press the service button inside the coin tower and you can choose the game assignment option from there.
When the cr2032 battery runs low on the CPU board inside the metal case, any saved settings are lost and the board will then default to being a 'Master'. So if 2 boards have both defaulted to master they will not be able to talk to each other.
There will also be 2 fiber optic cables that link each of the 2 sides together, basically TX (Transmit) to RX (Receive) and RX to TX.
In laymans terms, by the power plate at the bottom rear of the machines, the fiber optic TX/Transmit socket should have a red laser/light visible, and the RX/Receive socket should have no light.
So in summary, you need to verify that the settings in the service menu are correct by basically telling the game which side is the master and which side is the slave. And the cables need to be plugged in correctly so it can communicate, TX/redlight on side 1 to RX/non redlight on side 2, and RX/non redlight on Side 1 to RX/redlight on side 2.
You can also try setting both sides to single cabs and see if they boot independently.
DanP
Administrator
2,232CR
As already stated, there aren't really any mobile engineers these days who you can call on. Also you're mixing your generations quite heavily there, someone who could repair a 1980's Defender/Stargate is probably not going to be the same person who could repair a modern Sega Model 3 cab.
Your best bet is to try and hook up with a local collector who can show you the basics. Bear in mind we're all just collectors who do this as a hobby for the most part. We all started from the same point knowledge wise and built that up over time. Once upon a time I was close to Orpington, not so much now! See how you get on with anyone a little more local.
One word of caution, please be a little wary of any personal messages you get asking you to send the cabs to them and they'll repair them or of people offering to pick them up and take them away for repair. There are some unscrupulous people out there who might try and take advantage. Also bear in mind that if you go this route with a known/trusted repairer you'll be looking at £160 just in courier costs to get a cab too and from anyone who can repair them. Obviously the costs for a twin racer will be that much more.
Cheers,
Dan
Shaun1905
71CR
Thanks for the advice it really helped I tried them in single mode and they both work, one side has giant blocks of colour in the game so you can't see the road
Any thoughts on that ?
Shaun
Outrun2
Colonel Outrun
1,182CR
Regarding the Rally 2 cab it's 99% certain it's a simple fix as stated by Vamino - this is classic twin driver behaviour when they've been in storage (powered off) for along time.
If the fibre optic cables have not been removed then it'll be down to the MASTER/SLAVE issue described.
If you like, post up a photo of the screens on both cabs and we can verify.
Outrun2
Colonel Outrun
1,182CR
I was typing my reply as you were typing yours!
Good that both sides work - we were right on the link issue. You should be able to get them linked again without any problem.
Not such good news that one side has graphic issues. This could be one of the boards in the game board stack failing - this is located in the base under the seat in a big metal box (cage) if you don't know. It's common for video boards to fail on these, but sometimes if the cab has been moved it could be chips on them coming loose and needing to be re-seated.
This is not an exact science and will involve switching off the cab, opening up the base and taking a look inside the cage.
Were the cabs stored in a dry environment? If it's not dry/warmish and free from damp where they are now I'd postpone any further work until it is - damp is not the friend of old electronics.
