Capacitor help please
8,292CR
I’m having brain drain...
Can anyone help me work out is this a bad
Cap or when measuring caps
Is 0.25 more or less than 0.5 ?
Esr graph says worst case reading would be 0.5
Actual reading is 0.27
Is that less or more than 0.5?
Retroman8392020-05-17 19:47:42
5,332CR
Heh, I haven’t played with an ESR meter in decades. Duff caps usually stuck out like a sore thumb (orders of magnitude out).
I’d presume high ESR is bad - it is usually when speccing a cap (it reduces the capacitor’s effectiveness if it’s got a lot of parasitic resistance in series with it, limiting current flow).John Bennett2020-05-17 20:10:30
8,292CR
cheers for the help john,
i actually have gor parasitc drain on my vw van right now , but that can wait,, ( im reconnecting van battery every journey lol..... } because
i got monitors to sort out...
like i know a lower ohm reading fine
my max ohm value for this particular capacitor is no greater than 0.5,,,
but where my brain has trouble understanding what I'm actually doing is
i got a reading of 0.27 0hms. now if this was units of hundreds /tens /and single units.
then 0.27 would be l less than 0.5
but I'm not familiar with electronics and its crossing my mind that
it could possibly mean the ohms are climbing up from 0.5 ala 0.6 0.7 0.8 0.9 0.10 all way to 0.27
therefore 0.27 being greater than 0.5
is 0.27ohm a higher ohm reading than 0.5 ohm ?
and if so is it more ohms = less resistance ?
therefore a bad cap?
69er
1,854CR
the chart on your meter is a guide to 'TYPICAL' series resistance ohms of the device ITS NOT A 'SET IN STONE' result …………. that 0.27n should be ok?????? but check a similar device cap on your ESR meter to compare results is best advice ?
plainly 0.5 is half of 'one' ohm and 0.27 is just over a quarter of an ohm ie less resistance the lower the number PLAIN DECIMAL readings ie if your 0.5 was 0.49 or 0.51 that would be identical to within 100th of an ohm …
the confusion arises when a 'good' capacitor measured on a std multimeter should read very high or infinite insulation ohms except for the needle movement during its charging period
I will try keep this simple A CAPACITOR ALLOWS AC CURRENT TO PASS WHILE 'BLOCKING' DC CURRENT
this is because it has an ability to store electric charge and has two conductors separated by an insulator (resistance ) doubling the expected voltage it will hold double the charge treble the voltage it will hold 3x the charge up to its safe working maximum in a battery supply or circuit supplied with controlled DC volts 160vdc in this case 100uf
electrolytic caps are used when higher value of capacitance is required in a small component which is why they are common in power supplies acting as smoothing 'filters'... capacitor tolerances are fairly wide and vary a bit , some + 50% to maybe - 20% too from 'stated' capacitance which like resistor values you only get a range of selected used values 10 22 47 100uf etc because the value can vary so much
22uf covers 16-33 ….then 47uf covers 40- 65 ………. and 100uf covers say 75 -160 .. 220 same variant %
just like resistors only use a range of values & +or - 10% so most values can use one or a combination of two or more (connected in series or parallel to get nearer """another lesson there""")
( 1uf is a 'millionth' of a Farad ) ONE FARAD IS A LARGE UNIT OF STORED ELECTRICAL CHARGE
eg if its facing a steady say 5v it will or should maintain 5v at the positive side ….. IF then a wave of high frequency spikes of say 15v then it should drain those off immediately as they appear along with the current flow via the resistors also ……often to ground ov…..
the facing stable 'held' voltage is already controlled by a resistor network to maintain the expected voltage and is usually in parallel with the capacitor ………. so the cap is placed to regulate what you might say are unexpected sudden changes (often a 'spike') not handled quite so speedily by higher resistance elsewhere in the circuit.....
if you use a different model of ESR meter you might get 0.6 on those values and in my opinion tho I rarely use one unless I am upcycling pre-used salvage caps that's an ok reading at approx. 0.3ohms
just look at the ESR meter chart it gives same 0.15n 0.25n for both 220uf and 470uf at 63v & 160v max volts rating ……… if it was 0.00 or real low its no good as it will probably let dc pass by … and if it gets notably high its no good either as it does not allow ac to pass ( ie too much insulating) SO THE PRECISE READING IS A GUIDE and open to slight fluctuations different makes and ages of capacitors will vary the reading
also check out charts on other makes of ESR meters too they will often give a different typical ohm value ?
69er2020-05-17 21:57:43
69er
1,854CR
one point of use never fit an electrolytic capacitor direct to an AC circuit because if the positive terminal sees a negative voltage potential it will cause severe damage ,, variable voltages superimposed on a steady level of supply are allowed and thus enable them to work as they do ………
on power supplies the AC passes via a RECTIFIER to make all the negative going waves into positive going peaks and then smoothed by the large capacitors then after that point to give DC
the dielectric insulator on a fairly new capacitor is to a degree self repairing if it sees a sudden high voltage within reason , during manufacture a thin layer of aluminium oxide is spread over the spiralling plate of one terminal and it is very strong of an insulator providing the high spikes are not too excessive
but for the same reason these must NEVER be connected wrong way round ie, polarity sensitive
if you connect two or more in parallel of any uf values then the total capacitance 'storage capacity is the sum of all added together ie 2 x 100 uf side by side will store 200uf
however if you connect them in series the capacitance reduces to lower than the smallest one in the chain that has a formula for calculating it ? handy if you cant get exact size anywhere?
AGAIN AS WE OFTEN SEE ON HERE THE STATEMENT IN THE POST ABOVE MINE '' I know nothing or only a little about electronics " " I am not familiar with electronics ", to be exact
except maybe ......… electric harms or even KILLS …. its invisible …. it can do things you don't expect and heats things up to the point of FIRE breaking out , ……….
does anyone fancy basic electronics lessons ?? its not easy but far better than 'no knowledge' I will go right back to correctly wiring a mains plug if desired...…and list the basic minimal tools recommended to get by safely….
69er2020-05-17 22:56:12
8,292CR
Thanks.
So 0.27 ohms. Being that this is 50 percent lower than 0.5. This is still ok?
This cap is in series with another of same value.
And both measure similar ohm value...of 0.27
Thanks a lot again for the above info I’m going to study it well.
69er
1,854CR
take them both out of the circuit and fasten the pos leg of one to the neg leg of the other and ESR the two together you will perhaps get a reading closer to 0.50 n on your ESR meter
So if as you say two identical caps are like that in series ie a ' chain' the capacitance is going to be around 50uf so why have 2x 100uf when you could sling them in the bin and fit ONE TIDIER looking 47uf to same effect
are these just soldered to each other at one position in a chain system as I assume here ? two in one set of holes ? NOT side by side
sounds like someone has been messing with this circuit and not had the correct replacements?? in the past ………
you really need ask gunblade for more specific advice as I think this is maybe a NANEO monitor you have referred to in another post ?? it may be normal practice or may not?? . if its working don't touch it if its faulty get expert advice...…… just for the sake of re-capping WITH FULL KITS its not always necessary to do the lot .
69er2020-05-17 23:51:24
8,292CR
Why does
Or how does the power alternate.?
That’s a strange state?
Is it that the power station is alternating it?
So it flows but is alternating.
Then the rectifier only lets positive through for dc the other side
All negative power is separated away to ground.
Caps or resister arrays finish of the job by smoothing
Do capacitors amplify? Like if it says 160v. Is that simply the voltage What it will be expecting to receive on its its its positive side? Or is this what it will charge up to then release ?
69er
1,854CR
ARE YOU RELATED TO """" ANT & DEC """" ????(wind -up merchants on TV) ? in a round about way that's sort of an explanation JUST CAN'T THINK how you got to that though?????????? its not exactly what happens and the components do all sorts of different functions …… you need to learn more
I am beginning to wonder whether you should be opening the back of any arcade game and especially plugging it into the mains while its open !!!!!!!!!!!!!
you don't seem to have much of a grasp of anything electrical and I am not criticising you AS I AM THE FIRST TO SAY " IF YOU DON'T KNOW --- BEST TO ASK FOR HELP OR ADVICE "
but you really need to visit a library and get a 'basic electronics' book out on loan ,,
you certainly should not -in my opinion- be changing capacitors in monitor chassis ,,,,,,, sorry !!! safety first here !!!!!!!!!
69er2020-05-18 08:55:31
gunblade
9,138CR
cap meter is fine for checking caps, also for example a 1000uf reading at about 900uf is fine
an esr meter would only be useful in a very sensitive circuit on something like a pc motherboard, a chassis is far more forgiving
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Best to get a cap tester that tests the value and esr. Although most
bad caps I end up replacing usually still have a pretty close to correct
value but have really high esr.
Like this 10uf cap
Still only use it as a guide as it's not going to tell you if the cap is leaky, how it behaves at higher voltages, how it behaves when it gets hot etc. So if it's old, some times it's better to just replace it.
8,292CR
Thanks guys,,
Im having to go the long way round
So I have a non working
Ms9
Ms8
Wei ya tri
Wei ya 31k
Hanterex 14
2x sanwa pm175
3 x sanwa pm somethingthe 31k only vga chassi
All with tubes,.
I got more monitors too that I’m tinkering with...
So I’m just taking caps out and checking them... 1 by 1
I have already checked the hots
I’m starting to thing that the flybacks are bad...
As caps have all been ok...
One hot was bad... on the sanwa pm1745z
I’m thinking a fly back ringer next...
Or I will have to set up
The light build test rig...
