Capacitor Voltage rating
jonhughes
1,156CR
Hi everyone,
I need to change a few capacitors on a PCB. How sensitive are the PCBs capacitors to the voltage rating for a substitute capacitor. For example, I need to change a 2.2uF 50V axial capacitor. A 2.2uF 100V is readily available and reasonably priced. Does this create problems?
Thanks for any help.
jonhughes
1,156CR
Ok, thanks for the help. The only reason I ask is that I saw a pin restoration on here and the guy used a capacitor with the same capacitance but different voltage rating and size. It sent the DMD in the pin haywire if I recall, replaced the cap for an identical one and everything went back to normal. I just wanted to check.
4,058CR
Higher is OK within a certain tolerance, which you're not going to know unless you're the designer of the circuit to be honest. Is there no 63v version available? 100v will probably be fine but you are doubling it.
And as the guy found out on the DMD, sometimes the application is more sensitive than others, meaning it is not true to say that the higher voltage is ALWAYS ok. Unless there was another difference between the two. Higher should be fine and you're unlikely (I'm making no guarantees though) to kill anything.
The other thing you've not told us is what is this capacitor being used in? A monitor? A power supply? A game board? "PCB" is a little generic really as loads of things have PCBs in them.
jonhughes
1,156CR
Thanks for your input everyone, I see more detail is required. The capacitor is for a gaming PCB and an axial capacitor is required. Not as easy to find as the radial type. I need about 3 of them.
