capacitors HOTs
PinballToys
15CR
hi all
thinking about the HOT on a g07 monitor there's a capacitor C01 which is 150pF 1.5KV ac.
this appears a difficult value to buy in the UK, is it OK to go down to 100pF or better to go up to 220pF
and if any one has an RS part number that would be very handy!
i just wondered what people fit should they break the original when replacing the HOT
cheers
bob
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
capacitor value always has to stay true to the value it needs to be nut voltage can change
always ok to go higher but never lower
unless you know the circuit very well and know the min and max voltage going into a cap don't go lower
example: if you have a 5v circuit and its a stable 5v and you choose a cap rated to 12v which is fine to use, and you know the circuit will never go higher than 5V then you can replace with a 6.3v cap but not with a 3.3v cap
Mitchell Gant
888CR
Unless other people have successfully swapped out this capacitor for other values without damage, I'd be cautious about changing it from the specified 150pF. I certainly would not risk any lower voltage rating than 1500V, it will need that rating as a minimum.
I think it's known as the flyback capacitor and is important in determining the length and size of the flyback voltage pulse. It forms part of a tuned circuit with the flyback transformer so could stress that or the flyback transistor and cause failure.
Sorry can't help you with a source of replacement capacitors, hope someone else can.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Also from what I understand (I may be wrong) an AC rated capacitor is in fact a NP cap. No Polarity
maybe that's why your hitting dead ends to find one, look for NP caps and you may get lucky
tb2000
3,579CR
I'm assuming you mean the ceramic disc cap attached to one leg of the HOT. If so then one of these will do the trick: http://www.ebay.co.uk/itm/VISHAY-BC-COMPONENTS-F151K25Y5RP6UK5R-CAPACITOR-150PF-2000V-Price-For-5-/171229916533?pt=LH_DefaultDomain_3&hash=item27de192d75
