rockbottom said:tb2000 said:Exactly what I was thinking! As long as there's an FPGA with enough
power and gates, I would've thought there's a multipin socket or
whatever that can be soldered in place of the chip and the "repro"
slotted into it. I suspect it'll happen at some point (hopefully!)
The hardware side would be tricky, not least the 5v -> 3.3v aspect as it's virtually impossible to find anything 5v tolerant that would be big enough. But certainly possible somehow, even if it was a small sub pcb with 160 wires to solder I wouldn't care if it meant a working A board![]()
But that's actually the easy bit...
First you've got the actual decapping and delayering of a donor chip. The B21 was done by arcadehacker (actually someone else did the decap, can't remember who) I think they focused just on the small section that contains the programming logic and sram that stores the key.
Now, if they did capture the whole chip (hi res photos etc.) and they're available somewhere, then that's a massive step taken towards doing a B chip replacement. If the A chip has been done at all, I have no idea.
Next up, we've got the real business, the actual reversing of the logic at the silicon level. It takes somebody very knowledgeable in such things to be able to recognize individual gates and interconnections, and then even with a veteran of such things, it's a very time consuming and error prone job, eventually turning the whole thing into a giant schematic or logic definition.
I remember reading Furrteks blog, how it took something like 200+ hours to do just one of the NeoGeo customs!
Hopefully someone capable will step up. I'd certainly donate towards the effort, I'm sure many others would too.
lix said:Well mine had solder bridges across some of pins as I had to clean them up before installing, so they were at least tinned and not checked, they definitely weren't pristine.
John Bennett said:I used to aspire to recreating the chip by trying to 'infer' the contents by looking at similar hardware and older Capcom stuff (2D is all variations on common design techniques)....
Ace` said:lix said:Well mine had solder bridges across some of pins as I had to clean them up before installing, so they were at least tinned and not checked, they definitely weren't pristine.
Interesting, you got them from utsource? maybe they did resort to pulls as they started to run out then. Mine all had the same date codes and were very clean with no sign of solder.
rockbottom said:John Bennett said:I used to aspire to recreating the chip by trying to 'infer' the contents by looking at similar hardware and older Capcom stuff (2D is all variations on common design techniques)....
Interesting, I often wonder if looking at how the bootlegs work would help as well, after all on the face of it they seem to implement both the A and B with usually something like a TCP10 or ACT1 (early 90's field programmable gate arrays), handful of PAL/GALs and sprinkling of discrete.
Sure they're far from perfect but they're doing the bulk of it.
Perhaps one could even use some NOS 5v parts, I often watch auctions for such, some interesting stuff comes up time-to-time, job lots in 100s etc. enough for a good run, not like one would look to make a million.
Brettster said:I got a couple delivered this week, they look mint, just need to figure out how to reprogram them now
Also heard the A board were 1.5's with the sound hardware repopulated I guess that's where these NOS C boards have come from
Equites said:Brettster said:I got a couple delivered this week, they look mint, just need to figure out how to reprogram them now
What games can be used on these C boards?
Monstermug said:Brettster said:I got a couple delivered this week, they look mint, just need to figure out how to reprogram them now
Any links to where I can find A boards from?
Yes you can use Aarons rom patcher to make any game work with these c boards.
lix said:You don't have to, I find it easier to program the B-21 to be whatever it needs to be and it keeps it all as original hardware and eproms.
The C board will need the battery removing and modding to permanently default to B-01 if you use patched roms.
Personal preference and depends on if you use them to fix individual CPS1 boards or are planning to use with a multigame conversion.
Monstermug said:Ahh I bought two of those c boards and plugged in with patched and unpatched roms and got blank suicided screen. Should I just remove battery and try again with patched roms?
