Capkit Tips needed!
chunksin
21 (100%)
733CR
M K L said:
Replacing all the caps on a chassis is noob remedy. They cannot diagnose problems so they think that replacing all the caps will solve the problem or improve the performance, as if chassis problems were always cap related. I'm a regular on the KLOV forums (Americans are crazy about capkits) and there are countless threads titled monitor not working after cap kit. And in those cases they're very simple chassis like G07, K7000, etc. A Nanao trisync is way more complex and not just because there are more caps but because all circuits are more sophisticated, static sensitive, crammed with SMD parts, fragile pads and traces, etc. A lot can go wrong. Small electrolytics (like small resistors, diodes) aren't easy to deal with as their leads are bent outwards on the bottom of the chassis. Noobs heat the solder and force them out by pulling them from the other side or try to straighten the legs and in a lot of cases this results in damaged/lifted pads, i.e. more work to do and the chassis will be in worse condition than before.
There are just a couple of minor issues which a capkit may or may not fix, if it doesn't resolve the issues completely I can fix the convergence with strips which I've done before and adjust out the geometry as best I can. Thanks for the advice though, I saw a picture of the underside of the Nanao chassis yesterday and I hadn't appreciated how many smd components there are all rammed up against each other. I've done plenty of soldering projects so am quite confident about what I can and can't manage and if I'm not 100% about a cap I'll leave it be!
robotech
823CR
if you are struggling i will have a go at it for you but it wasn't hard from what i remember i have re capped a lot of arcade stuff since then :) and you don't live far from me
