Centipede board problems
Body pop
24 (100%)
1,266CR
I’ve two centipede boards down at the min
One is showing nothing on screen at all
Other is showing in pics below ,and in test mode
Would any of you clever guys ,know if there would be something I could swap from the dead one to get the other going?
There’s a good 5v and I’ve reseated roms on board below
Equites
Chief Sheesher®
35 (100%)
3,329CR
Looks like logic failure to me fella.
If you send me both I can refurbish one and send it back to you keeping one. Just an option.
patzik
388CR
Looks like the board is running but part of the graphics is missing, I would start looking at the graphics ram for this one. The schematic of centipede is really good so this will really help you out.
For the board that is not showing anything, check all required voltages (which I think you did) then look at the clock. If these are ok, then check cpu (you could swap this with the other board if needed).
With good power/clock/cpu I would expect to see at least something on the screen.
Body pop
24 (100%)
1,266CR
Thanks for the detailed explanation .appreciated
