centipede weird bored issues (wrong colors)
BlocksRR
4CR
I have a centipede cabinet that I've been working on for a while and after replacing so much im just not sure what's wrong at this point, I've replaced all the roms including video roms, I've recapped the ar-2 board with new transistors/voltage regs, ive replaced big blue. basically it boots up with some missing sprites and colors wrong and as it runs it starts getting more and more messed up with more missing sprites and the colors even more wrong. my voltages are (measured on the pcb)
5v=4.7v (ive messed with this and cant get it to work any better on any other voltages)
22v=25v
-22v=25v
15v=15v
-15v=-15v
-30v=-13v (kinda low but im not sure why)
test mode also has no beep but otherwise seems fine
here is the images of what the game is doing: http://imgur.com/a/WqyTyBj
BlocksRR
4CR
i can get the 5v to 5v with the 5v adjustment however the board just keeps resetting at that voltage. the -30 i have no idea what's giving it that since i dont think the ar-2 outputs -30v so im guessing it must be something on the board, i guess ill see what leads into that -30v and look around there.
yorkshire_spam
765CR
Random colors would suggest to me something wrong with the _COLRAM signal on the board.
Worth checking the 74LS32 at A4 and J3 as a starting point to diagnosing the issues. If everything else is working 100% then those would be my first guesses.
How we set-up are you in terms of test gear/tools?
