chase hq steering problems
griffo83x
30 (100%)
746CR
hi all
do any of you know anything about the steering on chase hq , ive not used the cab for about a month as Its not had a monitor chassis this is now sorted. so I thought id have a go and as soon as I turned the wheel had a horrible clicking sound , it looks the the little wheel on the end of the steering column was the culprit god only know how as its sat there untouched and worked fine before hand. I have tried adjusting the little pcb on the side but the wheel is bent out of shape now and I can only turn left. On the pcb they must be sensors of some type im guessing ? does any body no what the parts are or do any of you have this wheel and pcb in a box of spare's somewhere
cheers paul
Hurray Banana
2,761CR
The pcb has to opto sensors - consisting of an emitter and reciever. When the wheel turns the opto receiver gets the emitters light when the gap in the wheel passes. By having two the pcb can determine which way the wheel is turning and how fast.
They may have died.
minwah
238CR
Is the wheel metal or plastic? Hard to tell from the pic.
Atari use metal ones which can sometimes be bent back to flat(ish), but I think some other manufacturers use plastic wheels.
Being able to turn one direction is probably a result of the wheel not being properly aligned between the optos - probably too close to one side. I have had this exact problem with an Atari wheel. If it is possible to flatten out the disc, and/or use small washers to centralise the disc between the optos, then it may well work.
If the disc is buggered, you might be able to use one from a trackball. It looks like a similar size/type to that used on Happ 3" trackballs.
griffo83x
30 (100%)
746CR
thanks for the replys I have just taken it apart and the wheel is made out of plastic it has a few cracks on it along the edges I flattened it out best I can , I have cleaned th sensor's and put it back together with the wheel in the centre of the sensors , but its still the same so im thinking its a sensor at fault ,they do not have a part number though if anyone know please let me know
jengineer
49 (100%)
1,205CR
sounds like the wheel is catching on the opto sensor, drop the CP and then slowly turn the steering wheel until you can see what its catching on
jengineer2015-07-17 18:17:42
griffo83x
30 (100%)
746CR
hi Duncan its not catching now I have centred the wheel between the opto blocks but its not working :(
strykr
1,351CR
Rule out dirt on the optos first. cotton bud and some iso. I may have a spare opto board knocking about somewhere if you need to replace.
As an aside, I find it quite surprising just how many chase hq's seem to have 360 wheels, all the ones i played on bitd were all 270 pot based.
griffo83x
30 (100%)
746CR
hi mate , yeh already cleaned with iso and cotton buds , ive a spare chase hq pcb im gonna try tomorrow just in case ? , failing that if you find that opto board let me know I would appreciate it :)
cheers paul
strykr
1,351CR
pm me some more detailed pics of your opto pcb paul. I'll have a look.
I'm sure you have tried, but is there a config for the steering in test mode?
griffo83x
30 (100%)
746CR
I will get some pics tomorrow , and I will go into test mode and try my other pcb too, cheers paul
obcd
3,830CR
Those opto bridges are pretty common, but they don't all have the same gap width between the led and the fototransistor. It shouldn't be difficult to test the board, as the signals are pseudo static if you rotate the steering wheel slowly. You will have a GND and PWR wire to feed the led's of the two opto bridges, and you will have 2 outputs from the photo transistors. You might be able to see the (ir) led's glowing if you look at them trough the camera of a smartphone. You can simply check the output's of the photo transistors by measuring the voltage with the opto bridge blocked and unblocked. (simply put an object between them) to block an opto bridge. When you turn the steering wheel, you should also see the signal change between blocked and unblocked, on both outputs. Make sure you have the same voltage levels as you had with previous tests. Sometimes the led isn't giving enough light, or the bridge isn't blocked enough to get the correct voltage levels. You will still see a difference between blocked and unblocked condition, but the board won't accept the levels. As the board still sees you turning the steering wheel in one direction, at least one of the opto bridges still works properly.
strykr
1,351CR
Well that puts my cotton buds and alcohol solution in its place
obcd
3,830CR
I am more in favour of the cheapest fix which involves just replacing or repairing the one broken component or soldering.
The U shaped components are opto bridges. On one end, you have an infra red led and on the other you have a fototransistor. When the light of the led falls on the fototransistor, the transistor will act like a closed switch. When there is no light, it will be like an open switch. The holes in the disc rotating between the opto bridge make the led visible to the foto transistor.
obcd
3,830CR
Why not measure the 2 opto outputs? They are equal so it should be easy to compare them both. They both should show the same signals.
