Chase HQ
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
This was bought with a monitor issue. Apparently the vertical hold wasn't working.
Thought I'd have a look at the chassis as it was already out of the cab.
One wire had come off the neck board, but couldn't see anything else obvious.
Thought I'd put it back together to see for my self what it does.
After a bit of a tweak I get this :)
The vertical hold pot does seem a bit iffy. It was very hard to sync and does still do a single flicker now and again. it's definitely playable but want to get it sorted.
Do you guys think it could just be the pot? Or is something else more likely the cause?
JohnnyChaos
325CR
Found the vertical hold pot had a broken leg. Now to find a replacement.
Also ended up with an I/O Error today. Seems to be linked to the steering because if I set the dips to say the cab has a 360 wheel then it loads up fine. Seems to play ok like that too?
ZedEx48K
8-Bit
1,423CR
can you just not use a few strands of wire to bridge the pot and board?
The wheel is prob cos it is optical rather than a pot on those I believe.
JohnnyChaos
325CR
I did solder a new leg on to it using a leg from an old cap I had. But it didn't seem to help. I'm going to try swapping it with one of the others next I think. At least then if the problem changes then I know its definitely the pot.
Dan_k
Mo-derator kiss of death merchant
47CR
You could change the whole PCB here (In other Hantarex spares) if you don't have any luck finding the pot on its own.Dan_k2013-04-27 13:43:22
JohnnyChaos
325CR
Right the monitor says WG276539 on it. Which I can't find reference to online.
I've replaced the v hold pot and it's still not holding for long. Thing else to check? I found reference to a similar issue on a different wg monitor which was linked to two resistors.
JohnnyChaos
325CR
Well I've replaced the pot and it made no difference. I found a fault flow chart for this chassis and following that changed IC2 and C22, but I'm still getting jitters and rolls.
It sometimes holds for a little while, but as soon as the screen goes blank it starts rolling.
The flow chart also mentions setting a transistor. What does that mean? There isn't anything to set on it. It's just a little 2n3904
forcefulfil
EDOT King
17 (100%)
1,675CR
i had a sililar fault recently on a W&G
Turned out to be a dry joint
i re-capped it and changed the pot too,to no avail,then re-floewd it after looking for dry /bad joints
also make sure 100% the monitor is the same on another machine/pcb
ive also had this and it was the bloody machine not the monitor
JohnnyChaos
325CR
I have no other pcbs that are low res which is frustrating. All my other stuff is Naomi or chihiro. I got an SCI board with the cab but it doesn't boot at all.
I have found a couple of dry joints, two cracked pots and one lose wire so far!
found the lopt has a crack in it and its the one with the white knobs which i understand is a bit naff.
i cant hear any cracking noises coming from it though.
