Chassis was working now nothing ?
8,288CR
I have two Toshiba pb6643-1
From Konami Toshiba tubes…
Windys
Club gti
Etc…
Strange goings on
Connecting up both this evening
1 known good i removed from a bad screen burn tube
To use on a better tube and it worked..
But I was getting what sounded like high voltage leaking maybe around the top of fly back was hard to tell
Where it was emanating from excacltly..
I had a good raster. Turned off
Swapped in the other chassis … excactly same sound ?
No image couldn’t see neck glow..
Swapped back to the first chassis absolutely nothing
No sound no raster no clicking completely dead..
Swapped back to the other chassis I have good
Kneck glow no high voltage sound no raster …
1 chassis doing nothing but did fully work..
1 chassis has good neck glow no raster ?
On the better side I did get a bench multi meter today as well
So I can check voltages on my next visit
Just don’t know why one chassi worked fine but now is totally silent?
thegreathopper
1,253CR
Wow I am always impressed how many repairs you have going at once, I have just recapped one of these chassis it was a pleasure as everything was spaced out nicely.
Good luck with the repair, are you using the correct tube I wonder..
Vamino
Insert coin(s)
2,698CR
I had a Chungwa PF that was working then died during soak testing.
I tried the chassis on an exact monitor at Shanes/Robotechs.
My chassis blew his tube and then his tube blew his chassis. The lot went in the bin and we both vowed to never to touch Chungwa monitors again.
Hope you sort out your issues.
8,288CR
Yeh I have a few cab projects on the go now for a while…
But I’m Where I want to be with it..
Which is cool…
I have space now test my monitors & chassis..
Just going through seeing if anything I can fix myself with limited Knowledge.
Then sending off for repair when I realize that I cannot fix it…
It’s just strange normally something pops
Of there is X-ray protection or some noise ..
I’m hoping it’s my transformer or leads …
Or an easy part fix…
Could it be the small transformer in the power section?
I just don’t know where to look ..
My trusty multi meter just wouldn’t play ball today!!!
But I have a new bench meter I can use next time …
Also I do have another tube for these tosh pb6643-1 chassis which works but has a bit of burn..
That’s why I removed it.
So I guess I can try these On That tube next as well…
Retroman8392022-05-22 21:25:34
8,288CR
I have 2 chungwa
1 pfx
1 14” with pentranic
Tried again today same…
Problem with these two chassi
But I noticed same bad burned tantalum’s
On one chassis the cap next to it was bulging..
I’m now dubious if I grounded the dag wire!
So kneck pcb wouldn’t of been grounded…
Could this burning be the result?
I think I might have caused the issues by not grounding the dag?
Retroman8392022-05-23 17:12:56
