Cheap Logic Analyser
4,058CR
Ok, I'll have to have a nose at the Intronix software on my repair PC as it's Windows only...
There is an optional add on board for the SUMP LA which buffers the 16 unbuffered pins and completes the 32 channels. So I guess that's it :eek:)
I think what I might do is play with the Intronix software and then compare it to the SUMP software. See how much is missing from the SUMP sw.
[EDIT] Got a bit of re-arranging to do in the repair room tomorrow so may not get to much this weekend
guddler2011-03-12 19:29:27
Setch
The nice ad-min
542CR
Hi
Just wondered if anyone that brought one during the last batch of auctions actually received the item, im still waiting for mine to turn up after purchase on 9th March, I cant remember how long shipping was quoted at but as ebay has removed the auction now its proving a pain & no response from the seller.
Setch
trm
2,877CR
Same situation here - nothing has arrived and other than the email from seller saying "ebay kicked me off, they will still arrive" I've had no comms despite repeated attempts.
Am tempted to cross my fingers and make a magic "wish" that his website falls over temporarily to see if that helps him remember us
Setch
The nice ad-min
542CR
Not even sure if a claimback can be done now the ebay auction have gone.
Martin, how long was delivery from purchase ?
Andy
4,058CR
That's cool to hear - the seller seemed genuine enough on the few emails that I had exchanged with him. Though he openly admitted to the copyright issue!
4,058CR
Good news that it turned up! I would thoroughly recommend going and downloading the software from the guys blog though before completely sticking it on the TODO pile. Just in case that dissapears!
The device itself seems pretty good, though limited. I do tend to run into data rate problems with the USB on mine and have to switch it on and off a LOT to get it to work but I'm using an Intel Atom based "PC" in the repair room so I strongly suspect it's that that's the real issue. I had particular fun on Saturday night when I was tryinig to use my USB based programmer to do serial in-circuit programming over an SPI interface and it wasn't working, so I was using the logic analyser to view the data. Didn't like the two things being on the USB bus at the same time. I got the data captured in the end though. The trigger setup is particularly crap though I ended up capturing shed loads more than I wanted!
One very curious thing is that I keep getting the message that the device will perform faster if it was put in a high speed USB bus. Well, AFAIK, all the sockets on my Revo are USB 2 so I don't really know what' occurring there. I'll need to check!
4,058CR
So. Has anyone else actually used their Saleae clone analysers yet?
I seem to be getting very random and unexpected results. For example, I was playing about with my Arduino earlier and got it outputting a 7 bit binary count on 7 digital pins. As I was just doing this on my computer with nothing attached to the Arduino I figured I'd connect the LA to the outputs so I could test and see the outputs but I'm not getting anything like what I was expecting.
I'm wondering if I need some pull down resistors or something, but then I shouldn't really need them as each pin is being directly driven either high or low on the Arduino. So now I don't really know if it's the Arduino code or the LA being crap!
Any thoughts?
4,058CR
Nope, and i think that's the issue. I've put a jumper between GND on the Arduonk and GND on the LA and it seems to be working now. Not something I ever remember because the Saleae Ligic has an 8 pin hookup lead and the real one has a 9 pin so as to include the GND.
Turned it into an 8 bit counter for ease of reading the values at D7 seems to go high and stay high now but that could easily by my code. Just checking what Arduino supports by way of unsigned ints and bytes Vs signed.
Certainly looking better now though :)
[edit] Sorry for bad spelling - on me phoneguddler2011-06-16 20:28:23
4,058CR
Bingo! Bug in my setup code D7 was still set as an input. Interesting that I was able to drive it at all, even for only 1uS
All working as expected now though.
So, I guess no-one else is using their analyser then?
4,058CR
Hope everyones downloaded the software! Although the seller's blog page is still there, the download link is now a dead link.
I've supplied the software to Tim this evening though so I think it's going to get put somewhere. Somewhere that no-ones going to insist it get's taken down!
DanP
Administrator
2,232CR
Hehe, mines still in its bag too, soon to be placed on the "look at when I've got time pile" which will probably be when I retire at this rate...
trm
2,877CR
Hi all,
Sorry not had chance to get on the board for the past couple of days due to work
The software can be downloaded here http://ultrax.org/trmatthe/logicanalyser/ which should be fine as you're allowed to download the software from the original site to evaluate.
I'm still intending to investigate the more frequently updated installer to see if you can move to a newer version. Martin provided some useful info and I've already done some messing with the temp folders created by the official software so I'm pretty sure I can get it to work with the this version. I'm going to be a free man again from Wednesday so expect to see some VAC stuff coming out quite soon after
Edit: Minor edit to make it clear I'm reverse engineering for compatibility, not for any nefarious purpose.
trm2011-06-18 16:38:42
4,058CR
Cool!
Quick update from me. Yesterday I tried the stock latest software. Not surprisingly it didn't work. In fact the software actually crashed and exited when I connected the analyser. But it didn't brick it or otherwise do anything nasty to it either. So I guess it's safe to play*
*Disclaimer: In my experience only. Only tried OS X. Usual terms apply
guddler2011-06-17 16:28:43
