Chihiro bios upgrade
petercasino
212CR
I've got two Chihiro motherboards, one I can NetBoot and one that I can't. I'm using the same key in both. I've looked at the bios versions in each one and noticed they are different. Could this be the reason why one works and one doesn't?
The versions are:
Working
Boot version 2.19
Sc firm version 1.10
Media board version 4.0
Non-working
Boot version 2.11
Sc firm version 1.09
Media board version 1.15
Is it possible to upgrade, and if so how?
Mike
Brettster
1,276CR
Hi Mike
Im pretty sure it's possible to update them, but im not sure you can do it yourself
send AndyGeezer a PM,
I know that the Media Board needs to be on 4.0 to be able to play games from CF or SSD drives etc but not sure when netbooting was possible
obcd
3,830CR
The media board firmware can be updated with a gdrom for that purpose. If netbooting is possible, you can use that as well. The latest official media board firmware is 4.02. There is also a 4.03 floating around in the wild that removes the restriction that only official sega compact flash cards can be used. It wouldn't suprise me that the gdrom updates the other 2 firmwares as well. On fleabay, someone was selling such an update gdrom, and his picture shows the software in action. It shows 3 firmware versions with some marked "up to date" If you have a gdrom drive, you might find people willing to send you the update disk. You need to pay the shipping costs and need to ship it back after use. Can't remember if it's Andy Geezer offering that service. (And maybe not to everyone)
Chihiro 3 unit's are critical when using netboot. If a valid game that uses networking is present in it's memory, the game takes over the network adapter approx. 30 seconds after bootup. From that moment, netbooting is no longer working. Removing the netdimm battery for a while until the memory becomes corrupted removes that restriction.
As even Naomi's with a netdimm and the chihiro 1 with a netdimm allow netbooting, it would suprise me that there existed a chihiro 3 firmware that isn't having the feature.
I assume you have checked the media board jumpers and are sure they are in the correct position for netbooting?
The update mostly exists because the older firmwares don't allow to use a compact flash card instead of the gdrom. (And the gdrom was proven to be unreliable)
petercasino
212CR
Brettster said:
Hi Mike
That sounds correct as my SSD drive also doesn't work with this motherboard.
Thanks for the info.
petercasino
212CR
Yes the dip switches are in the correct position for net booting. It also attempts to boot from the network. When I go into the settings menu, the motherboard hangs when I go into the media board network settings menu item - not sure if this is because of the wrong firmware?
Unfortunately I don't have a gdrom drive, only an SSD one and that doesn't work either. What's the going rate for gdrom drives?
obcd
3,830CR
They quickly ask 60 - 100 euro for a second hand gdrom drive. It's a waste of money if you only need it for the update.
Maybe there is an issue with the media / network board of the non working chihiro. You could try the other chihiro with the older firmware together with the working media board. If that works, you know that the media/network board are suspected. The media/ network board are in the upper cage of a chihiro 3. It's easy separated from the lower cage.
Our outrun 2 at work never was updated. I know netbooting works on it. I could check the firmware revisions tomorrow to see if they are equal, older or newer.
I am a bit confused. How did you ever use the other chihiro without gdrom drive? (Since it's not accepting netboot or ssd)
petercasino
212CR
I'll try swapping the media board and see what happens - thanks for the suggestion.
I bought the 2nd motherboard on it's own (without a gdrom drive) as I was planning on net booting it.
obcd
3,830CR
You could have answered.. Non of your buissiness which would be correct as well.
If it works with the other media board, you can even exchange the network board which is the smaller board on the media board.
obcd
3,830CR
I just noticed you mention media board firmware. I assume this means you have a chihiro 1.
Our HOTD3 chihiro 1
Boot 1.09
QC FIRM 1.04
SC FIRM 1.03
Media Board Firm 3.03 (Vxworks)
Our Outrun II chihiro 3
Boot 2.03
QC FIRM 1.08
SC FIRM 1.08
DIMM BOARD FIRM 1.00 (RX850)
Network board firm 11.01(VXWORKS)
Both units netboot fine with this firmware.
Chihiro 1 can't be updated with a disk. It's only possible with a chihiro 3
(At least that's what I was told)
http://forums.arcade-museum.com/archive/index.php/t-273987.html
This also says you will need at least 3.03 as media board firmware.
obcd2016-08-12 17:55:47
petercasino
212CR
Both motherboards are type 3.
I've tried swapping around the media/network boards as you suggested and it looks like the network card from the original non-working motherboard is dead. Using the good network card I can get both motherboards to net boot. Thanks for your help.
If I want to link the two machines together do I need 2 working network cards? Or is there another way to link the machines? I noticed there's another network port on the bottom of the motherboard, can this be used for linking the games?
Mike
obcd
3,830CR
To my knowledge, the bottom network port can't be used.
Why would Sega add a network board if things could work without it?
The sega network adapter has it's own cpu and operating system.
The bottom network port is connected to the main cpu.
My guess is they did it to reduce the load on the main cpu so that it has all resources for the game it's running.
As previous netdimm modules could be used on Naomi, chihiro and triforce, it also looks like sega doesn't like to change proven working things.
