Chihiro maintenance
channel27
1,376CR
Hi all,
I'm in the middle of a F355 -> Outrun 2 conversion and I thought it was about time a tackled my  ridiculously loud Chihiro.
The plan is to change the case and GPU fans, check for leaky caps and clear out the 18 odd years of dust.
Case fan
I looked up the spec of the case fan and sourced a replacement that on paper claims to move the same amount of air: -
https://www.amazon.co.uk/gp/product/B07D74LXBW/
It runs at slightly lower rpms but it seems to be shifting significantly less air, despite the similar CFM rating. Has anyone got a better alternative they can recommend, please?
GPU fan
I found a 40mm fan adapter for the Xbox GPU on Thingiverse that I could 3D print and use in conjunction with a Noctua NF-A4x10 FLX. Has anyone else gone down this route? It seems to work really well. I'd be happy to print off some others if anyone wants one?
Leaky caps
The notorious caps around the GPU that are known for leaking seem to be as good as the day they were fitted. This one, however, is a ticking time bomb and needs to go: -
Am I right in saying that this is the superfluous baseboard Supercap that can just be removed?
Needless to say that job is next on the list!
Cheers guys,
Rob
channel272021-02-22 22:59:57
Vamino
Insert coin(s)
2,698CR
Those fan mounting shrouds look cool,
Not
sure if that's your Chihiro, but that fan is blowing upwards rather
than blowing down on the heatsink. It should be more than enough to cool
the GPU TBH, I'm using some 40mm Delta fans we used to use at work, I just
screwed them into the heatsink.
When
I serviced my Chihiro's I also applied some new thermal paste, think it was Shin-Etsu. The old
chewing gum stuff can be a bugger to get off by Arctic clean 1+2 did the
job wonderfully.
Vamino
Insert coin(s)
2,698CR
Well just found a spare fan and the fans I used for the GPU are 45mm @ 12v.
The fans for that shroud need to be 40mm.
https://ystechusa.cdistore.com/products/detail/yw04510012bh-ys-tech-usa-inc/485597/
They are quite loud compared to the Noctua fans but you can't hear them over the other fans noise. They move 10.3cfm which is more than enough when compared to the original Chihiro GPU fan which is pretty crap tbh.
Some 60mm Noctua fans are 5v so be careful.
The fan you linked to on Amazon is 60mm @ 12v @ 35db so it's a bit louder than the Noctua @ 19.3db.
Vamino2021-02-22 22:49:03
channel27
1,376CR
Hi,
Thanks for looking but yes, that’s my Chihiro. I went down the Noctua route with that 3D printed adapter.
The 60mm one I’ve linked to is for the case fan. It’s rated at the same airflow but it feels like it’s moving a lot less in practice?
Did you change your case fans too? My system is a lot quieter now but I’d trade some more volume for better cooling if another fan is more suitable :S
Thanks for the heads up on the fan direction! Doh! I’ll flip it when I remove the capacitor
Vamino
Insert coin(s)
2,698CR
I didn't bother change the case fan mate, the 120mm fans in the cab are noisy as hell so it seemed pointless to spend money buying new fans when the old ones do a good job sucking the air out of the case. Think I may have lubricated them but can't remember now as it's been a while!
I think Chris/Teminator2k stuck some fans on the outside of the Chihiro case sucking the air out, the pics may be on the forum somewhere.
Sbdesign
SEGA collector
1,721CR
This is a good idea, I think reading this lots of people will be paranoid, thinking that their own machines need a little attention after seeing this.
For clarification...
The GPU fan needs to be blowing down?
The case fan needs to be blowing in or out?
Interesting concept with replays (in that link) to switch between naomi and chihiro.
Fantazia2
2,246CR
Someone once said to me the best of option for cooling a PC was having fans blowing in to create air pressure inside the case but then also having ventilation so the pressurised air can escape, that way you have a constant flow of fresher and hopefully cooler air passing through the case.
Vamino said:
Look like they are blowing into the case, not sucking air out.
Don't think it stood a chance of overheating!
Sbdesign
SEGA collector
1,721CR
Interesting,
Gets quite contradicting when you google also.
But many illustrations similar to this....
Makes sense. But can't remember exactly how the Chirhio looks (vents/holes etc)
Sbdesign2021-02-23 08:51:35
channel27
1,376CR
I replaced the case fan as it was making a horrible grinding noise.
I've got new AC fans for the cabinet itself too so hopefully I'll be able to enjoy Magical Sound Shower in all it's glory without too much whirring in the background
Those external fans look like a great idea.
The case fan blows air out, so I guess that the external ones should suck cool air in? There's a ton of holes all around so I guess the exterior fans will cause positive pressure inside the case that can escape out the of holes (supplemented by the case fan blowing it out too)
First things first tho... must remove that leaky cap
Vamino
Insert coin(s)
2,698CR
The GPU fan blows down on the heatsink to cool it and the exhaust fan on the Chihiro sucks air out of the case. Sega used to have fans blow directly onto the chips but it caused dust build up which killed quite a few Daytona stacks.
This guy explains it quite well (From 6 minutes and 4 seconds):
Model 3 should have fans exhausting air out of the cage but I've seen them blowing air in, not sure if they always did that but I've seen them pushing air into the case too..
Over the years of building PC's I like to have a positive pressure setup with filtered fans at the front of the case pushing air, and fans at the rear pulling air out.
This generates an air tunnel effect where hot air doesn't have a chance to build up and because the air going in is filtered there's not much dust build up because nothing is getting sucked into the case from anywhere else.
With negative pressure, there's more air going out than going in. Even if you have air filters on the intake fans, dust can get sucked in from all over the case and it quickly builds up.
Gamers Nexus or Linus tech tips did an experiment with positive and negative pressure setups, they left the PC running 24/7 for ages and then checked out how much dust had got inside in each instance.
Mark H
98CR
Hi All,
"Jay" from this forum has just removed my clock cap on my original Xbox and done some general maintenance so he may be able to assist anyone.
channel27
1,376CR
Hopefully this is good for a few more years now.
Supercap removed and the GPU fan is now blowing downwards: -
Check your caps! It looks like I removed this one just in time. Luckily the area around it has cleaned up well.
Anyone know why the motherboard has writing on it? (bottom left of the GPU) The case still had intact seal stickers before I opened it so I guess it came out of the factory like that?
channel272021-02-25 08:20:26
channel27
1,376CR
*** ATTENTION ***
This is your triennial reminder to check your Chihiro caps.
This is a working board and it looks like it’s been caught just in the nick of time 😮
funk
555CR
I've heard all sorts over the years, I was a big overclocker in my youth, still dabble but it's a lot easier and less fun these days. I remember driving my parents mental having a deltec fan that ran insanely loud on a 1ghz CPU running at 1.4ghz, had a controller built for it as it was before the time the tech allowed for the fans to be controlled by temp too.
Back on topic though!
It totally depends on the case and surroundings the kit is in, in my experience. Tidying cables if possible can make a huge difference. In a traditional case, my general go to after literally years messing around is to have one exhaust at the rear, at least one exhaust on top, then one or two at the lower case front, so you're sweeping colder air in, which is drawn to the top, the CPU fan is pushing the heat from the heatsink that rises or is drawn to the rear and top exhausts.
A lot of people insist on mounting some on the bottom to blow air directly up, but dust ends up being worse that way.
Although they're ugly too, the volume of air high end fans like noctua shift are amazing compared to generic ones, run quiet too.
Re the caps they were notoriously bad as I'm sure we're all aware from about 99 though to 06 from what I've been told?
I've got a lightly used original Xbox and another that was battered, all revision 1.6 though which I believe has better caps installed, all are still fine at the moment, but I'm never sure whether they just degrade, or degrade with the length of actual use?
Vamino
Insert coin(s)
2,698CR
*** ATTENTION ***
This is a working board and It looks like it’s been caught just in the nick of time 😮
Holy crap!
Is that the one I sold you? Looks like it may have recently blown?
I've had that in storage for well over 5 years, pretty sure we replaced the larger caps on all the boards, the blue ones to the right of that blown cap maybe?
I'm gonna have to check my other ones now.
