Chihiro problems :(
FinalFight
73 (97%)
770CR
been working on a outrun 2 conversion cab lately and just wanted to get it finished so i can move it on.. Had to get the media board updated to accept my official outrun flash drive .. but i keep getting error 26 then not long after it switches the monitor to black screen .. i spoke to craig he said error 26 is normally a security chip not matching error but the shutting the screen down sounds like a fault :( pretty sure the pic im using is the right one as i wrote on paper next to it in a box..
i got my other chihiro out and powered it up it just had a black screen.. opened it up the fan on the gpu not working so thats probably dead now :(
anyone had any similiar issures with the screen switchin off after boot?
Im gonna give up i think tbh stegrey2019-04-12 17:24:06
obcd
3,830CR
Normally, the error 26 should stay on the screen. It can be the security pic, but it can also be that it simply doesn't recognise the flash drive. If you change the dimm board JP9 jumper to netboot mode and disconnect the flash drive, does the image stays on with a checking network or other message at the bottom? Have you inspected the chihiro main board before trying it. The one farad clock capacitor is prone to leaking. You can simply remove that one and clean up the spillage. Make sure the gpu fan is working if you haven't tested that already. (You can just power up the unit without the upper dimm case.) Another common cause of failure are the capacitors surrounding the cpu. If they are bulged or have some brownish spillage at their top, they will need to be replaced. While the boxes are separated, you might check the base board cr2032 voltage as well. Another thing to check is if the supply voltages are within tolerance. As you seem to have a twin setup, you could test it out on the other side. If you go into test menu, does it operate normally there?
