Chihiro (running without game)
FinalFight
73 (97%)
770CR
I was testing 2 chihiros out early on tonight without having a chip/game .. I could hear the startup sound but both had a black screen.. is that normal? Do they need a chip and gdrom running to get a picture?
Ste
FinalFight
73 (97%)
770CR
I only have 1 Avip cable but i tried mikes (petercasino) working cable too and still both had a black screen :/... we thought maybe you do need a disc and chip.. his chihiro has the Pi setup and the chip doesnt have a case so would of been a pain to remove to test on minestegrey2017-07-19 00:15:43
5,658CR
Did you buy them working or untested? They have LEDs on the system that should give you more information by deciphering the flash codes.
FinalFight
73 (97%)
770CR
I bought them both working from china and they had pictures of them in the test mode showing the serials.. I should of checked the leds
obcd
3,830CR
What is the startup sound you are hearing? Some boot sound or just the blowers starting up?
On the front filter board you have 3 led's that light up with the 3 voltages and a red and green one. Normally the green should be steady on.
The Chihiro outputs a 640 x 480 x 60Hz signal. It has the vga connector VSYNC pin unconnected.
Most modern pc monitors don't like that resolution anymore. If you test with an F355 cabinet monitor, it should work as it should have a VGA (640 x 480) capable Nanao or Sanwa monitor.
Unsure what other status led's people refer 2. There are a couple of led's on the dimm board, but they also just indicate some voltages are present. There are four on the smaller network board on top of the dimm board. They are initially all on. After boot, one is off and one is flashing if I remember well. I assume you got the units from Ebay? A seller there seems to have several, and maybe he's using the same info screen picture for all of them? I am unaware of led's that flash a sequence to indicate a fault condition, but happy to learn.
A thing you could check is the dimm board battery voltage (if the battery is there) If it's measuring no voltage it all it might be better to disconnect it.
FinalFight
73 (97%)
770CR
Thanks for the Info :).. yeah it was on ebay.. each board has a picture of it running and the serials of the boards are on the test screen .. i checked them and they do match up to the chihiro.. I could hear the startup tune just no picture :(
Outrun2
Colonel Outrun
1,184CR
I'm assuming you have the VGA cable plugged in correctly?
Have you opened them up - is the battery present? Are you sure the dips are correct as Ian mentions above?
FinalFight
73 (97%)
770CR
Hi gary i was thinking maybe i had the vga cable in the wrong side but they are both different? .. i had a look and the battery packs are there.. we compared the dips to mikes and they are set the same... Thinking back when i tested them i plugged them up and when we tested mikes he plugged it up so maybe i have done something wrong.. i cant work out what though
obcd
3,830CR
You can check your vga cable to see if there are no bend pin's or pin's that broke off.
Normally, you shouldn't be able to connect a vga plug the wrong way, unless you use extreme brute force. The moment it plays it pling sound, it should show the chihiro logo on a lightgray / white background. Without gdrom / security pic it should show an error message on the bottom of the screen.
FinalFight
73 (97%)
770CR
Went back to mikes tonight to check the LEDS and both chihiros worked .. both confused
least they are working though
Thanks mike for all your help
obcd
3,830CR
Good to hear they both work. Do they work at your place as well now?
2 Things you should check on the main (xbox) board of chihiro's.
1. There is a 1 farad capacitor (The clock cap) that is known to leak after some years. It's better to remove that one as the leackage is corrosive and can damage the pcb traces surounding that capacitor.
2. The gpu has a small fan on it's heatsink to keep it cool. Make sure it runs well and isn't covered in dust. That fan stopping to rotate and the gpu overheating is the most common cause of chihiro failures.
obcd2017-07-19 23:25:46
FinalFight
73 (97%)
770CR
Yeah glad they are working now.. I havent got a jvs cab yet.. I thought i would get one again easy :(
Thanks for all your help :)
Yeah im going to strip them both clean them and replace the fans and check the cap.. any idea wheres best to buy the gpu fan?stegrey2017-07-19 23:27:28
