chihiro type 1 problems
griffo83x
30 (100%)
745CR
hi , i recently purchased a chihiro type 1 to go in my initial d cab
on installing the mobo i can not get any picture or sound
i have noticed on type 3 mobo there is a lead that goes into the mobo , it looks like a xbox lead
do i need this for the type 1 ?
any help advice would be great as this is all new , and im not sure
thanks
well got the lead this morning and now all i get on screen is any ideas , i get a little tune when it boots up , i can hear the game running , i was told that i would not nbeed to alter the monitor settings ? i have checked the dip settings and they seem correct. any help advice would be great this
griffo83x2014-05-07 14:45:25
Outrun2
Colonel Outrun
1,181CR
Yes you need the AVIP cable on both type 1 and type 3.
You know you're limited to OR2 and Crazy Taxi High Roller on type 1 (driving game wise). OR2SP will not run on a type 1 Chihiro.
griffo83x
30 (100%)
745CR
cheers
i thought as much so i have just ordered a lead from andy geezer
yeh i knew about the games , but i will be happy with or2 for now, maybe get a type 3 and sp at a later date
4,058CR
It could be as simple as setting the dipswitch for video output to match what monitor you have in your cab. I believe (someone will quickly correct me if I'm wrong) that Chihiro can run in 15Khz (CGA) or 31Khz (VGA) by setting a dipswitch. If that doesn't match the type of monitor in your cab you'll get no picture.
Ordyne
1,282CR
The game shouldn't load on any other setting than 31K as you should get an error.
That said DIP settings are 1,2 & 5 off, rest on..
griffo83x
30 (100%)
745CR
hi thanks for that the dips are set as you say , im gonna try it in my stand up naomi cab over the weekend and see if i can get a picture on that , before i mess with the monitor in the id cab
thanks paul
griffo83x
30 (100%)
745CR
here is a short vid of the chihiro running on the initial d cab
https://www.youtube.com/watch?v=5ZDSXO-JiSk&feature=youtu.be
i have tried altering the hold but makes no difference :(
Outrun2
Colonel Outrun
1,181CR
Sounds like a stupid thing but have you proved initialD runs fine in this setup? You've only swapped over the Naomi for a Chihiro right?
I've never had sync problems when dropping a Chihiro into an iD cab - maybe the width adjustment would need tweaking a little but nothing like this.
Have you tried jiggling the VGA connector on the Chihiro while the game is running to see if it makes any difference? Maybe a bad connection - a mate had a Naomi with a faulty filter board which produced erratic visuals so could be the problem..
4,058CR
Yeah, can you confirm for sure what Khz monitor is in that ID3 cab? I know ID3 should have a 31Khz monitor in it, but whose to say it's the original monitor?
IndyJones
"Partial to Tooty Frooties"
375CR
He does not seem to be online atm, yes the cab was running ini d no probs, he took it out to convert to or2, he has done another vid to say that the chirio comes up on his naomi cab fine but just won't work in the idi-d cab?
griffo83x
30 (100%)
745CR
hi all yes initial d works fine on naomi 2 mobo
i have just hooked up the chihiro to my naomi cab and runs fine ?
video at
https://www.youtube.com/watch?v=ZmBAHUG5MIM
apart from swopping the monitors over i dont know what else i can do ?
griffo83x
30 (100%)
745CR
hi yes initial d runs fine on this cab, i have a vid of the chihiro running on my other naomi cab so i know the chihiro is ok . very strange ?
i will try giving the cable a wiggle failing that a good ol whack on top of the cab . .lol :)
griffo83x
30 (100%)
745CR
hi here are some pics of the monitor, i should also mention it was running id3 no problem
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I don't have the first clue how to help you but here is RETROREPAIR selling a upgrade from Type 1 to 3 kit
http://www.ukvac.com/forum/fs-chihiro-type-3-512mb-dimm-network-board_topic338578.html
