Chihiro Type3 Booting?
JohnnyChaos
Blows own trumpet for CHQ cabs
325CR
Does anyone have any experience in CF adapters or Netbooting a Chihiro Type3?
I got a security chip which I know works in a naomi for netbooting and I'm told (by the seller) the hex is the same as the chihiro one.
But I can't get it to work in my system and just keep getting error 26.
If I use an original security chip I can netboot fine which leads me to think the modded security chip isn't compatible with a chihiro type3.
I've tried changing pin9 and using my CF adapter in stead, but that just gets the error 26 as well.
Can anyone help?
Setch
The nice ad-min
542CR
Hi
I had the same problem with one of my security chips, there are 2 different types as things changed during the development as far as I am aware, its the ABC & XYZ hex reference in the patched ISO's so you have to make sure you have a matching keychip to what your booting, I think the latter was XYZ and this is what the images available on the net use.
One thing to remember is that the CF method only works with the official Sega CF solution, there isn't a hacked version of the Chihiro Firmware that allows the home built version to work or self made CF cards, if you are using official kit then please ignore this.
Also remember that the CF solution works as replacing the GD-ROM drive so you have to put the dimm back in into GD-ROM mode and not netboot mode for it to work, again assuming you have move the jumpers to put it into network mode in the first place.
One test that you can try is changing the region of your board to see if the chip is working as if its not then you wont be able to do this.
Go into system information screen then press service button 15 times until GAMEID appears. Then press service a further 30 times. you should see some text turn green which indicates that you can change the settings.
let me know how you get on and will try and help out as much as poss.
JohnnyChaos
325CR
Does the abc xyz affect netbooting or just cf cards?
I'd heard about it for Naomi cf cards.
As for the region change. If I press service 15 times some text pops up at the bottom saying something like SBNL but if I press it 30 times more nothing else happens.
JohnnyChaos
325CR
I found a USA seller doing security chips and he does one for Naomi, chihiro type1 and triforce type1 and a different one for chihiro type3 and triforce type3.
So that suggests the chip I bought, which I know works on a Naomi, isnt going to be right?
Setch
The nice ad-min
542CR
Well after a new nights of looking through the source for the security key I can confirm that this issue is down to crappy security keys that have been created using the leaked source that is available on the internet.
If you Google Chihiro Error 26 there are a number of posts from various forums detailing this exact same issue so I can only assume various sources for these security keys are poor so beware.
While this source can be altered to create a security pic there are some issues with it that stop it from working on a Type 3 Chihiro & type 3 Triforce systems
With this I was able to replicate the fault described and have now managed to create a security Key that works on all the systems.
Sorry I wont be releasing the hex for this as I will upset too many people by doing so.
However as I've actually gotten off my arse and done something arcade related for the first time in ages I will be sending Johnny a key to get him up and running FOC, you have PM
I can now clean up my test bench and put this one to bed..
JohnnyChaos
325CR
at last I got round to trying this today and worked perfect.
I was able to change the region on my motherboard and netbooted OR2.
Thanks a lot Setch :)
JohnnyChaos
325CR
Ordyne said:
Releasing the dump has to be better than people having to pay for the NetBoot key off eBay?
That key on eBay doesn't work for type3 either as that's the one I got before posting this thread.
Not sure if he's amended his listing, but he did offer to refund me.
obcd
3,830CR
I know this is a rather old topic, but I am looking for a netboot security chip that works on chihiro 3 hardware. I am responsable for the repairs in an arcade hall, and we have an outrun 2 with a dying gdrom drive. I programmed a netboot pic with the mame code that floats around on the internet to figure out that it indeed gives an error 26 when used on the chihiro 3 hardware. It seems to work on older house of the dead 3 hardware. I checked ebay, but couldn't locate a netboot pic that guarantees to work on chihiro 3 hardware. I could dig into the pic sources myself, but it feels so much like reinventing the wheel. Further on, without knowing where to look, I would need to construct the security pic reader first to see if there are differences between a working and no working netboot chip. In worst case, I have to sniff the protocol between the netdimm and the security chip to figure out if there are new undocumented commands on the newer hardware... As we have the original gdrom's and security chips, I don't think netbooting is a form of piracy. Thanks in advance for all replies.
bbz149
26 (100%)
1,608CR
That's strange as I have a Type 3 and one of the Pics I have if not both work with my Piforcetools. Let me try them over the weekend and if the one I have in my Naomi 2 works which I'm sure I tested in the Chihiro with OR2 ill program you a couple
bbz1492014-09-10 22:09:52
