IDCHAPPY said:My other chihiros work fine on these settings, I've checked the visible jumpers on the comms board and bar jmp 9(which I think is to do with booting from gd rom or net dim) it's still the same.
I hope by the fact I'm getting something on the screen and it seems to operate that it's not totally f**ked?
These caps look a bit toast:
AndyGeezer said:This from Spain, if so then its fooked or so a little birdie told me.
Selling faulty sh*t as untested pee's me off.
guddler said:I'd say that's not looking too healthy either![]()
guddler said:Here's hoping it's the cause of your issues! Can't hurt to replace it anyway.
Bet that didn't smell good when it went up (not you would have smelt it given it was already like that)
JohnnyChaos said:For some reason I feel quite excited to find out!
guddler said:Absolutely! Clean the top of it gently with a bit of IPA (not beer!), make sure it's dried completely then put a small amount in a thin layer on before putting the heatsink back on. If you have it, make sure it's a good quality one intended for PC CPUs etc.
Ordyne said:..
Also change the GPU fan while you are there or you will have a box of worthlessness PDQ!
Ordyne said:Sorry to say that this isnt the cause of your fault, you are looking at the wrong board in the stack.
However what you're seeing isn't anything I've not seen before and why I charge top $ for the boards that I sell as I go through and check / service them for these very reason.
IPA will get that stuff off but it will struggle, if you have an electrical contact cleaner it will do the job better / quicker. Don't use cheap thermal paste or it will over heat and reset.
