Chip identity
bonehead
I'll get pix tonight
50 (100%)
1,729CR
If it is that does it need programming and where could I get one? The pcb reports the faulty but I’m just going by the test menu. I don’t fix pcbs so this is the first step I guess and was going to try piggy backing it rather than trying to de solder.
Ace`
PlanB contributor #1
40 (100%)
4,040CR
It's just a standard ram so it doesn't need programming, piggybacking *might* work it depends how the ram has failed (if it is actually bad). The self test cannot always be trusted but it is helpful for pointing you in the right direction.
obcd
3,830CR
It's not because the selftest reports the ram as faulty that it's indeed the ramchip itself that is faulty. A bad pcb track to one of the ram pins will cause the same faulty message. A problem in the ram chip address decoding will cause such a message as well. Together with the fact that a piggy back doesn't guarantee that the fault can be bypassed and the fact that it might be difficult to ensure that all pins make good contact (if those of the original chip are somewhat oxidated), it should be clear that your fault finding flowchart is not an "exact science" If you try it and it fixes the error, you know the original ram chip is bad. If the fault persists, it proves nothing.
simonden
20 (100%)
1,042CR
I get my spares of this chip from faulty sf2 boots which normally have a few socketed of these.
Piggy-Backing might not correct the fault, but worth doing and seeing if anything changes, just a slight change to the fault suggests it is the chip.
bonehead
50 (100%)
1,729CR
Ok thanks Simon I have a few sf2 boots.
I wanted to try this method as didn’t want to damage a good original pcb with my soldering skills.
Will report back.
