Clean Plexiglas
funhouse
362CR
I just wondered if it was possible to clean old plexiglass control panels from cigarette burns etc?
I have read that it is possible to remove scratches on CRTs, but can the same method be applied to plexiglass or will it just frost-over?
KmanSweden
148CR
I made this nasty woofer plexi look nice again with fine and superfine wet&dry (used alot of wather with some soap in it)
Before:
After:
KmanSweden
148CR
I can't recall.. Maybe some rubbing compound after the 2000grit wet&dry.
Important NOT to do circles. Up and down and side to side when sanding. KmanSweden2016-03-29 18:07:29
Mr20to5
1,366CR
Somewhere on here is my resto thread for a zacc invaders. On mobile so hard to sort links just now.
However the cpo had fairly bad cig burns on it, removed with extra fine steel wool, elbow grease and patience.
Novus is good, I tend to use car detailing stuff, purely because I already have it.
