Cocktail Electrics
NivagSwerdna
855CR
I am embarking on renovating the cocktail I bought last year...
and...
It seems to be an import (it has Japanese markings) which has been converted to 240V. I have never worked on one of these before but I can see it has a part where the power comes in and is fused there. Inside there are two transformers.. I presume one is step down from 240 to 110V and then the wiring is probably original. Many of the internal wires are perished and fragile.
I'm thinking of replacing the transformers with a switched supply from China.... I'm less sure about the monitor...
a) What is the recommended earthing scheme? Should the monitor chassis be earthed? What about the metal panels the joystick/buttons connect to?
b) Any ideas on power supply for the monitor? Do I need to keep a transformer for the monitor alone?
Sorry if these are silly questions... this is my first arcade device.
Regards
Nivag
obcd
3,830CR
Older monitor chassis need an isolation transformer as the chassis is connected to one of the supply wires.
In most arcades, everything metal is connected to earth, including the monitor chassis. If you have an isolation transformer for the monitor, you can safely earth the monitor chassis.
If you can tell us brand and type of the monitor, people will be able to confirm if it needs an isolation transformer.
obcd2018-01-25 23:11:56
backflipper
774CR
This looks like it has already been modified. The euro 2way power extension is not original nor is the large transformer and choc-block connector.
I would look into plugging a modern Switch Mode Power Supply into the euro power extension and confirm the voltage. If it's 120v make sure the SMPS is set to the same voltage.
You should investigate the power supply that is mounted sideways under the monitor on the right hand side. It looks like it is a PSU for the konami board that is in it.
