cocktail tilt switch
JohnBud
429CR
morning
i've got a carnival cocktail that is sounding an alarm ???
it is an arctic cocktail running carnival. the cocktail was stacked 3 up and was working fine. however when we drilled a lock and put it on the ground it seems that a tilt switch has been actuated
everything is as it should be game wise apart from the constant alarm.
does anybody know where it is sighted ??? it totally wrecks the game
cheers.
john.
god my fingers ache
obcd
3,830CR
There are 2 type of tilt switches often used on older arcades. One is a conical block hanging in a ring. When the block touches the ring (due to shocking or lifting the machine, the tilt is activated.)
Another type is basically just a contact with a small weight at the end of a spring blade. When the machine receives shocks, the weight starts to vibrate. This closes the contact so that the tilt is activated. It prevents people from banging the machine (like on pushers). So, look into your cabinet if you find either one of those 2 types.
https://guideimg.alibaba.com/images/shop/2015/10/13/84/pinball-balancer-over-switch-pinball-arcade-game-tilt-switch-plum-assembly_10903684.jpeg
That one is rotated 90 degrees. The weight is normally facing down.
http://www.thepinballwizard.net/images/products/elsw-0006.jpg
obcd
3,830CR
I understand you need the location. If you know what you are looking 4, you might figure it out yourself. Are you sure the tilt was a standard feature and not something the operator build in afterwards? If it's case 2, it could be anywhere where there was room for it. Aren't the interiors of coctails easy accessible if you unclip a few locks (having a hinge on the other side of the upper part of the cabinet.)?
