bringing this thread back to life as I have had development
Equites has been kind enough to send me a mech
the mech itself arrived broken possibly due to transit as the ceramic disk was broken inside
but that's no prob as the credit control is what I needed
so here is what I have
6-Way Connector
Pin Wire Colour Function
1 Brown Meter Drive Output
2 - Key
3 White Credit Output N/O
4 Green Credit Output Common
5 Black Supply 0V
6 Orange Supply +12V
CCU Supply Voltage 11 – 15 V DC, typical 12V DC
CCU Supply Current maximum 160mA, typical 90 mA
Operating Temperature 0 – 50 °C
NOTE – The power supply requirements for the validator in use with the CCU must be added to the
above values for PSU loading calculations.
Meter Output – Open Collector Drive to 0v)
The open collector output is capable of sinking 200mA at 1V. The pulse length is 100ms with a duty
cycle of 50% for multiple pulse outputs.
Credit Output
This is a relay, contact rated at 1A @ 24V DC or 0.5A @ 120V AC. The pulse length is 100ms with a
duty cycle of 33% for multiple pulse outputs.
Output ON Timing 85 – 115 ms, typical 100ms
Output OFF Timing 170 – 230 ms, typical 200ms
Pin1: im not sure what it is
pin2: key
Pin3: Coin 1 Lead
Pin4: Coin 1 GND
Pin5: Power GND
Pin6: +12V
what you guys think am I right or wrong and also if someone can explain pin 1 to me
