Coin Mech Info
Ropi Jo
127CR
Hi All.
Can anyone shed some light on this coin mech? I've got 2 of these. They seem to be 2 versions of the same unit, a C123.
I've got some info for another mech that's sort of close but not really getting anywhere with this unit. I've powered it with 12V where I think it needs to be connected but getting no response on the outputs and the solenoid is not responding. Info on the dips and the correct wiring would be great. A correct manual would be fantastic. But any help would be very appreciated.
Thanks.
Ropi Jo2018-09-05 20:01:29
qjuk
51 (98%)
2,146CR
If you look closely in your 2nd picture the pcb has C122 printed on it, yet the front label is C123?
The Money Controls C123 is a mode 5 mech which I believe is designed to be used with a separator.
The C122 is a mode 2 mech. I can’t find any manuals for the C122/C123 mechs but the Money Controls SR3 is the newer replacement for these so the pin out info is the same for the equivalent mode types.
For the C123:-
The two SR3 manuals which might help you are here:
http://www.moneytech.hu/letoltes/2012/2/TSP019%20SR3%20Type%202%20Technical%20Manual%20V9.0.pdf
http://slot-tech.com/interesting_stuff/money%20controls/TSP005%20SR3%20Type%201%20TM%20V4%5B1%5D.2.pdf
What machines are you trying to connect these mechs to? Standard video game installations tend to use the C120/SR3 mode 1 type mechs instead.
Ropi Jo
127CR
Hey qjuk. Thanks for your reply. Those links are the manuals we're 'using' at the mo. Can't find anything specific to C123 either.
They're not connected to machines. Just running on a bench. Trying to use them with a homemade change machine controlled by an Arduino. Just need an output that relates to the coinage inserted.
The mechs came out of a totally knackered Whittackers Roulette, the mechanics of which will be a part of our homebrew arcade... eventually!
qjuk
51 (98%)
2,146CR
I’m not familiar with the Arduino setup so can’t really help you there.
If you are applying 12V to pin 2, ground to pin 1 and make sure pin 6 is not connected then I would have thought you should at least see the solenoid responding when inserting a coin (as long as the coin entry flap and pathway is clean). Also, just check at the bottom of the mech near the coin exits, there should be some opto sensors, make sure they are clean. Also, hate to say it, but do you know if the coin mechs are actually good?
According to the labels on the mechs, pin outputs are: Pin 3=£1, Pin 4=£2, Pin 8=50p, Pin 9=20p and Pin 10=10p.
The bank of 6 dip switches are the coin inhibits. The bank of 4 dip switches are for Money Control use only.
qjuk
51 (98%)
2,146CR
Also, just noticed in your photo that you might be testing it with a new 10p coin! Since these mechs are old it’s possible they weren’t upgraded to the new spec 10p in 2011. Try the older 10p with the lion on or a 20p to be sure if you haven’t done that already.qjuk2018-09-06 01:22:17
Ropi Jo
127CR
The Arduino part is sorted. It's hooked up to control a hopper and just needs an input on a relevant pin and will dispense the appropriate number of coins.
The mechs are unknown regarding whether they work. We thought the same as you. Power it, stick some coins through that it 'should' recognize, and bobs your uncle. We've actually tried many different coins and not had a flicker of life out of it.
All coins exit the same path as when the unit is un-powered. No solenoid action at all.
We've tried pin 6 high and low, as well as floating, and played with the dips.
We will investigate further later on tonight.
Thanks for your help!
