coin mech not working
trickydickyy
1CR
Hi,
I have a asteroids cocktail cab, the 10p coin mech was working but all of a sudden it now returns the coins, the "odd" one goes through ok. Not being a techy on these things I'm not sure where to start.
Could anyone give me some points please before I end up taking the 6 bolts out and removing the whole lot to see if I can see anything.
Any help would be appreciated.
obcd
3,830CR
If it really is a coin mech, you should be able to follow the piece falling trough it.
It can be dirt or oxidation of some of the moving parts. You can easily test and adjust it outside the machine as it needs no power. It's detecting based upon size, thickness, weight and attraction of a magnet. Make sure the return button isn't stuck either.
trickydickyy
1CR
Thanks for the update , I'll set the game to free play and lift it out and have a tinker.
Is there anything I should be aware of or not do including any liquids to use or not use? The coin goes straight to return, so im guessing something maybe stuck, any pointers at all would be useful
obcd
3,830CR
Search on google for "coin mech adjustment"
I wouldn't use any oil as dust might stick into it.
Have a look at it while a coin passes. It might be obvious why it takes the wrong direction.
