Coin Mechs
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
Being a coin mech virgin I need some advice about swapping them over in the wife's prize machines... they are all set to 20p but I was going to change them to 50p( inflations and all that, most of the cash goes to charity as well).
What am I looking for?
grobda
1,061CR
on modern mechs (mars etc.) its usually a dip switch, settings will probly be on google once you find what credit board it is.
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
They all look fairly old Monkey and Parrot only take 20p through the hole, infact they all do.
Should just be buying 3 new ones and fitting them?
RygarR
413CR
What you have there is an S10 cradle with a mechanical mech. Because they are tailored to one specific type of coin, they don't usually have credit boards attached. To change the coin, you need to swap the mech. There are plenty on ebay that'll take new coins. If you have the time and tools they can be modded , but unless the new coin type is physically smaller than the existing one it looks a bit tricky...
simonden
20 (100%)
1,042CR
That is an S10 mech - they are easy to change coins in, I have done about 5 of them (albeit over a year ago).
They are just 2 screws to adjust for the coin, 1 does the coin thickness, the other does the diameter. Let me go grab one that I have to remind me how to do it.
simonden
20 (100%)
1,042CR
Yes - the red plastic bit is just a reject button and to hold the lamp and price. If it hasn't been glued together in the past, the front part of the plastic comes away (when it is out of the machine) so you can change the price label, which is just a piece of paper with the price written in white on a back background (so the light shines through the price).
It is not used to validate any coins, so the size of the coin hole is irrelevant (unless it is too small of course!)
IDCHAPPY
KANFU Master
9 (100%)
1,523CR
So these are the ones on Monkey and the parrot, I ordered one but it doesn't have the lock on the top part so is about 30mm too short
(that was a waste of £40
So I need a new 50p mech like this:
Any idea?
