coinmech woes
mysticmonk
1,051CR
Hello again, this time my problem is with a coin mechanism. Ive never given one a second look before, so heres what I know:
The coin counter works.
The microswitch on the first coin slot works for getting credits. (but it has no actual coinmech)
However the problem is that the blue box on the 2nd coin slot just lets all money run out and back to the refund slot. Ive tried every denomination of euro, all the same. (and it most certainly SHOULD be taking euro, but you can never be sure)
Im sure theres something really simple going on here, so any tips for what to try are most welcome! Thanks :)
gunblade
9,149CR
that is a sentinel mech, they were awful when they were new
does the credit button on the credit board work, do you have both 12v and 5v present on the credit board power input, check for bad solder joints inside credit board- normally on a couple of caps, are the dip switches set correctly as there are inhibit options, is there 12v going to coin mech
mysticmonk
1,051CR
This first video is what happens to mine.
https://www.youtube.com/watch?v=iibYaGhxuP8
Whereas the second video is what I want to happen, here
https://www.youtube.com/watch?v=2R02otisg4A
All wiring visually looks fine. Im at a loss when it comes to the dip switch settings on the credit control unit...
Is there a way to have it accept "any" coin through dipswitches? Im totally buggered if its only set up to accept old irish punt!
Edit: when I press the "test" button, nothing happens at all, which probably isn't a good signmysticmonk2019-02-03 16:41:06
big10p
Coins detected in pocket!
6,094CR
In that case, it's not sending a pulse so, as gunblade says, step 1 is to check everything is getting the required voltages.
mysticmonk
1,051CR
Thanks for the input guys, Ill get around to it eventually then. In the meantime as a quick fix, I can just get a bit of cardboard and create a "chute" from the 1st input to the microswitch. All good for now :)
