Colour palette differences
cools
I joined ages ago honest
19 (95%)
798CR
Anyone have a real idea why 80s JAMMA (and non JAMMA) games use a brighter colour palette to 90s games?
I've seen it thought that 80s = behind tinted glass, but I know from experience that the glass only makes a small difference to the palette.
I've also seen bits of information regarding the DC offset with AC coupled monitors, but this doesn't explain why there was a significant change in palette range around the turn of the decade. Did monitors suddenly change in their function?
Any ideas?
trm
2,877CR
Possible WAG coming up, could be easily shot down by anyone with more knowledge.
I think I've noticed (but it could be confirmation bias) that older games tended to use a resistor ladder to produce the RGB levels and often used 3 bits for red, 3 bits for green and 2 bits for blue to fit in their 8-bit byte data bus. So 7 shades of red and blue and only 3 shades of blue.
Newer stuff I've recently been looking at uses a 16 bit word as the move to 16-bit wide data busses for colour and it seems to be 5 bits per colour so you've got subtler colour steps and also transistors or custom silicon to produce the final analogue RGB. So 31 shades of each primary.
With 3 bits for red & green you don't have many brightness levels between 001 - dim and 111 - max brightness (even worse for blue, but retina biology comes in here too), so maybe it'd be a choice of 010 - pretty dim and maybe too dim on iffy monitors or 100 - bright on a decent screen and not too dim on a crappy CRT. A five bit range for RGB gives you double the colour steps.
I don't think the 0-0.75V P-P versus 0-5v P-P affects this though as almost everything I see seems to still be 0-5V, but I thought I'd mention it in case anyone knows better.
That's just made me think of the hardware which claim 16.7m representable colours which must be using 24 bit DACs.
P-Man
International man of mystery
1,273CR
The 'behind tinted glass' is mainly due to CRT technology of the day, the Phosphor coating was quite a light grey on most CRT's until the development of darker phosphors into the mid-late 80's.
The tinted glass was a cheat to improve contrast and create actual blacks on the game screen if you weren't in a dingy, dark, light-devoid arcade. Remember that most early games were coloured objects moving around on a 'black' background. They weren't screen-filled with graphics because the hardware couldn't handle that, this left a lot of 'grey' background visible, where the intention was for it to be black.. hence, the tinted glass.
