Component - Capacitor?
ataridude74
265CR
Is this an electrolytic capacitor?
As found on a monitor chassis, it seems way too small to be a 68uf 1000v electrolytic, the picture doesn't show scale but based on other values and sizes of caps it should be around 3 times as big. I cannot find a cap of this value anywhere either.
ataridude742020-04-14 20:26:17
7,230CR
Don't quote me but I thought it was 68uf as well.
Is thought it was 0.098k x 1000 = 68 ??
Can you pull it and test it for its value ??
Maybe this will help ?? Just found it
TheDaddy2020-04-15 09:54:50
69er
1,852CR
yes I would agree with john bennett above metalised polypropylene as the Cap in picture is not clearly marked as polarised (you could check pcb markings just in case) but electrolytic almost always have NEG >>arrow>>>> and andy confirms K is picofarads then The Daddy chart multiplys in 10x as it crosses the chart so 68 / 680 / 6800 pf then next size along is = 0.068uf
these are on ebay ? 2 PCS 0.068uF / 68nF 1.6kV 1600V ERO CAPACITORS. METALLISED POLYPROPYLENE ...at £4 plus pound to post
the max working voltage (1.6kv here) is not too critical as long as it is higher than what you may expect in the circuit its the capacitance which needs be close to actual value
or maybe you could search through my box of about excess of 5000 new and used for a close equivalent (I may be chucking these if they any good to you) salvaged used or unused from mainly commercial tv / amplfiers/ 80s monitors some may well have dried out and be of no use but I use an ESR meter just to give them a basic check but rarely repair stuff now.
you not too far away in stoke?
69er2020-04-15 11:41:19
ataridude74
265CR
Thanks all.
There are no polarity markings, only Nichicon and 2879, I assume a date code, so I reckon it's a polyproylene 68nf cap as suggested.
It's on a tiny daughterboard on the left of the chassis as in the photo below, don't know what chassis it is. Any ideas, it'd be good to pull the manual for it? It goes with a 14" Hitachi tube.
But as it's not an electrolytic and it is a Nichichon it should be OK to leave where it is.
69er
1,852CR
it is a Hitachi / Toei type of chassis very common back in the 80s … why are you particularly concerned about this cap (As you say its prob OK left alone) or are you just trying do a close to total refurb of the old cap type components ,,, an ESR meter should read that cap in circuit or lift one end and measure for a more accurate read? good chance its not faulty the main issues we used to have with those chassis was the inductor pcb on the right and poor contact wipers and dry joints developing on the several v/h hold colour gain and linearity pots along the lower edge. as they are often open to the elements. and getting knocked during normal use.….. I may have a schematic somewhere but don't hold your breath as anything here not seen for 5-10 years is often lost indefinitely
if I get into my garden shed anytime there is a good chance there's a few of those in there at the back
69er2020-04-15 18:32:42
ataridude74
265CR
I'm replacing the electrolytics (all FORTY of them) and at first look the mystery cap appears to be an another electrolytic. As it's not I shall leave it where it is, so down to 39
The monitor is working, but the picture is washed out and not sharp. Could also be the tube.
I can't seem to find a manual or schematic for it on-line, people have suggested in other posts it is a Toei but it doesn't match the manual for that monitor which I have (that had a poor picture as well).
Ropi Jo
127CR
Years ago I had my own TV repair business from my spare room. I pulled a faulty non polarised cap (1uf I think) from a chassis and stuck in a polarised cap. It worked fine. I was surprised. I went downstars to make a cuppa and then BOOM! Some lowlife had let a firework go upstairs. When I got up there the snow was still falling from the explosion.
The moral is.... DON'T MESS WITH CAPS!! Make sure it's a match.
Ropi Jo2020-04-15 22:53:18
