I would just ignore the iPac, if you are going to be switching between the 2 I would get some D-plugs to quickly swap between, or you could have them both wired together and put the earth on a switch, Ordy I think will have the connectors and pins so you don't need to hack the loom, otherwise you could just solder the ends of the cable and push em in the slot (not the tidiest but works and no loom butchery), the pinout is easy enough though, http://www.sega-naomi.com/forum/viewtopic.php?t=1488
