Control panel and marquee removal?
funk
555CR
So I have a cabinet with a marquee in the middle of the machine, under the control panel.
I want to get to the lighting as the tube has gone and has assumed the way would be via the control panel.
Problem being, I thought I knew how to remove the control panel, turns out I don't
https://photos.app.goo.gl/xj79Gaa8R7oyRxny9
On one side there were two screws that have been replacements for the rivet style fixing you can see across the panel.
Access from underneath is practically non-existent. I'm thinking removing the marquee is a possibility but it's well and truly fixed in tight, don't want to destroy it the first time I try to get it out.
Any ideas?
funk
555CR
After taking god knows how many videos trying to figure out what's going on, I've eventually located the latches! Not tried to free them but they're there
Carvaletingpro
118CR
Yeah open the coin door and pop out the right side door and there's 2 latches. There maybe 2 screws either side of the control panel if it won't come loose.
Try some a little wd40 down the marquee sides
funk
555CR
I'm in cheers, marquee light and starter replaced thanks :)
funk
555CR
Did you not have the control panel off, before ?
I'd figured I'd it out after messing with a camera to see what was up there. Simple and stupidly easy when you know where you're feeling.
