Control panel earthing
big10p
Coins detected in pocket!
6,091CR
Just wondering how important it is to earth metal CPs? I have a JAMMA cab that's earthed and another one that isn't, and doesn't look like it ever was. Thoughts?
Flinnster
The Dino King
29 (100%)
2,566CR
I've earthed all of mine. I've had the odd static zap to/from metal on the CP once in a while, so I'd rather that's discharged to earth than ending up on my PCBs...
karlcdoe
887CR
I believe they are supposed to be earthed really, on the offchance that mains voltages somehow find there way there. Wouldn't be unheard of if there are wires up to the marquee lamp nearby that have chafed through.
karlcdoe2017-07-14 13:20:57
5,414CR
Also it's one of those things that wasn't done quite so much back in the 80's when you think now all your house should be earthed
Mine was built in late 60's and no earth to light switch or bulbs at all, I've since added earths to it all and friend who's electrician earthed all the heating pipes when changed the consumer unit to split type
Electrocoin ones are earthed, but loads arent. Personally I'm adding earths to mine as I work through them just to bring the safety aspect upto date with regs these days
Sega cabs have most metal areas earthed
These Glendale Vending machines I was only thinking the same on last week, it's got earth to coin mech and the cage, so basically 2 things that someone could touch from using, specially kids, but the wheels aren't earthed and neither is the metal tray where you get the prize, I know it's fixed to the plastic so don't touch anything else but I was thinking surely that should of been earthed still. considering I'm going to be selling this Monkey when finished, I'm certainly adding an earth to some of the other parts
Bods2017-07-14 14:06:50
