Control Panel Holes
tazfaedodge
91CR
Can these be welded up and re-drilled in new places?
I drilled new holes in my panel for a forth button but got the alignment out, so it kinda looks daft to me. I also would like to fill in the middle hole for the joystick.
Is this possible? or should I just look at getting a new panel with the layout that I'm after?
Nick
obcd
3,830CR
welding will probably be difficult as it's a rather thin plate. You could place a second additional plate at the inner site of the panel. Fill up the holes with polyester (or 2 component epoxy) and flatten it once it has dried. You should be able to repaint the visible site. After all, that's how they fix car damage as well. It can be a pain to redrill a hole, if parts of the material are soft and others hard. (metal versus epoxy) You could drill from the bottom I assume. (The new plate without holes)
