Convergence strips
Mr Bond
76CR
Anyone know where you can buy convergence strips? Or has anyone got any they want to sell?
Got a Pacman cab and been adjusting monitor for hours as top right corner is dropping.
Cheers chaps.
chadsarcade
Lord of Vectors (tm)
443CR
Your convergence looks pretty good, there doesn't look to be much colour separation in the dots in that corner - mine are well separated. Somebody on J+ did some convergence strips, I don't know if they are on this forum.
The picture looks slightly trapezoid, wider at the bottom than at the top in the [rotated] picture above. Depending on the monitor there might be pot hidden away for this which you can tweak.
chadsarcade2019-09-26 07:20:38
Mr Bond
76CR
Not sure. I’ve tweaked pretty much everything.
Done a cap kit, new flyback. It’s a Elec G07
The picture was wider on the left. It sloped off at top and bottom on the right side.
Only just got cab but had to do a lot of adjusting on monitor. The convergence rings wernt secured down also so had to play with them a lot and managed to get it nearly straight on bottom but not the top.
The top right corner also, the colours are slightly separated compared to rest of screen.
Not a fan of these monitors at all when it comes to adjusting them. Nightmare holding a mirror in front and reaching around back. Already been zapped when rotating rings. Might have to invest in some gloves lolMr Bond2019-09-26 08:17:28
ColinD
6 (86%)
1,367CR
Colours look fine, Looks like you mean the linearity of the picture ?
I'm not sure if the convergence rings will adjust that out and thought that they were just generally used to align the colours.
I'm sure one of the monitor experts on here will know for sure.
Mr Bond
76CR
No rings are just moving the guns. I’ve played with it more today. It’s as good as I can get it.
Picture is nice and sharp with the new caps, just a shame it’s off at the top.
One of the pots adjusted the trapezoid effect, whatever you call
It but it won’t alter enough to straighten it out. Mr Bond2019-09-26 19:11:04
