Conversion Harness No Power??
86CR
Made a conversion harness for my Astro Fighter, but not getting power out of it.
I've read the voltage running the original board but as soon as I connect to the harness 0v.
Is it possible the power is coming through the board stack?
Excuse the dust, not hoovered the bottom of the cab since I picked it up.
Goodwinsplace2017-10-31 20:18:28
grobda
1,061CR
where did you get the wiring diagram?
from this one; http://www.arcade-museum.com/manuals-videogames/A/Astro%20Fighter.pdf
it looks like there is an extra power connector (wiring can be seen in pic as the dusty wires leading to back of pcb stack)
seems no power goes to the edge connector.
apologies if the adaptor you made is for a completely different boardset, but it looks wrong. also if you're going to chop a 28 pin jamma fingerboard down i'd remove the pins that are wired together.
86CR
seems no power goes to the edge connector.?
Thanks for the reply. The manual and boardset is different to my setup, think the Deco version used a different pinout.
I had to make my own pinout by continuity checking each with a meter.
I spotted the same in the manual and the dusty cables at the bottom providing the power.
One thing that is confusing me is the audio, there is only a single audio to the connector, do I need to go further into the audio setup to take a pair?
86CR
OK, I have power now from the bottom harness.
Getting a picture on screen but missing colours, I've assumed RGB based on wire colour on the original harness.
I'll take a look at the back of the monitor to see if I can get a pinout of the monitor and double check the colour wires.
Also not getting any sound, have the audio from the original harness going to pin 10 Jamma and pin 11 Jamma going to ground.
The 60-in-1 credits up and plays.
Does this need a serious Degauss? Or is there another issue?
Astro Fighter doesn't really use much white within the game.
Goodwinsplace2017-11-03 22:53:29
86CR
A bit of monitor adjustment and it's looking a lot better.
Still needs a degauss, but can live with that whilst I'm doing the rest.
Still no sound even though trying cable and ground both ways around, I'll have a look deeper in the cab to see if I can connect elsewhere.
Also having a random issue with the fire button not working in game but during 60 in 1 menu it loads the preview.
