Converting a Control Panel
940CR
Well it seems like its going to be mission impossible to find an Atari Time Pilot Control Panel, so I am going to have to look to customise this spare Atari Millipede Control Panel.
What its going to need is a joystick bang in the middle and another button symmetrically along the top otherside of the stick in line with the button hole already present. The two player 1/2 holes are fine and in the correct place.
Any ideas on how to do this, is it actually possible, artwork will obviously go over the top of this once done, but panel needs to be smooth.
Here are some pics in its present state.
Russ J
233CR
Best way would be to take it to a good metal fabricators and have them weld up the holes you don't want and smooth out the best they can,can't see any other way tbh....make sure it's a good fabricators as there are plenty of rough arses out there....not sure how much it would cost but this is what I would do if I had the same dilemma
Russ...
Russ J2016-01-24 09:25:00
dj_yt
787CR
I would investigate getting a new panel fabricated. Maybe there are economies of scale and you can sell a couple of spares to reduce overall cost.
For my electrocoin cab, I had the existing panel sandblasted, the holes reworked and then powder coated. But the changes I needed were less radical.
Russ J
233CR
well that's another option to explore,might be a good idea then your not hacking up an original CP
Price wise I wouldn't have a clue,my Robotron ones were £45 each (I had two made at the time) but the company I used were very quiet (work wise) at the time so I got them made quiet quickly any other time it would have taken longer and probably cost more I guess
bomjac
453CR
Should be a piece of cake to get the holes filled by any9ne good with a tig welding set. Fill holes, sand blast and prime and ready for cpo.
RGP I believe did have a source for fabricating goliath cp's at a reasonable price. Any good metalworking shop or sheet metal worker should be able to repro it for you. bomjac2016-01-24 10:06:31
strykr
1,351CR
Ben I just had a CP reproed and cut by someone in Eastbourne, good price and a good job, if eyou want their details let me know.
