Converting a converted signal
jonhughes
1,156CR
I'm restoring a NARC cabinet, the original uses a 19" medium res. monitor. I may as well go looking for rocking horse poo than one of these (so I've been told).
I have a theory though which may work around this (partly).
I have already converted the medium res signal to VGA, via one of these so I can repair it and get it going again:
http://www.ebay.co.uk/itm/Arcade-Game-RGB-CGA-EGA-YUV-to-VGA-HD-Video-Converter-Board-CRT-LCD-GBS8200-QI6P-/172055026497?hash=item280f475b41:g:3UUAAOSw5dNWjH6k
So I have a good image on an LCD.
If I convert that VGA signal to RGB using one of these, I should (possibly) be able to get it to run on a 15k 19" monitor (which are readily available).
http://www.ebay.co.uk/itm/VGA-To-CGA-Converter-Arcade-GBS-8100-/122064685320?hash=item1c6b9f4908:g:HkAAAOSwIgNXnJt5
These are particularly good at converting VGA from a standard PC graphics card to an RGB signal (for MAME for example).
What do we think? It would take away the LCD, which is the whole aim of this.
Hurray Banana2016-08-21 08:44:35
jonhughes
1,156CR
There is a separate issue where the first convertor cuts the edges off the image, like this one:
I may be wasting my time on this one if the image sent to VGA isn't a full image. This isn't mine by the way, just to illustrate the issue.
Fantazia2
2,246CR
Is there not a menu on the converter to adjust the image size and position.
Also why not try and get a 19" CRT Computer Monitor instead of converting it back to CGA again.
2,268CR
Medium res monitors are out there, they'll just set you back a little more than a 15k monitor. Best and cheapest option would be an open frame 19" VGA CRT, those are quite easy to find. Brand new boxed Pentranic ones were going for under £100 not so long ago. Have a word with tb2000, I'm sure he's got one he can sort you out with.
jonhughes
1,156CR
Had a bit of a scare today - the CGA to VGA convertor decided to crap out when I decided to have another go at making the image bigger. I didn't know that was what it was at the time.
I only have one of these so deciding what went wrong was tricky. I'm very wary of these things now since when it died it took out U1 on the main PCB which is responsible for the sync outputs. It shorted across pins 7 & 8 on an LS74-86 and I'm lucky that was all it did.
I don't think I'll be dabbling any more. Glad to see this back up and running on the works multi sync. It will take the signal direct without any convertor. I just hope the monitor I ordered will do the same thing.
I have fond memories of playing this in my town arcade, glad I own one now. Thanks to Purity for the P1 button.
Are those sides normal on the attract screen (yes they are - just checked YouTube)? The actual game play looks fine. My MAME cabinet is away and I just have no clue.
Nice image on the LCD.
jonhughes2016-08-21 20:25:26
Purity
The Oracle
17 (100%)
2,999CR
I was offered a really nice looking Narc. Didn't know you were into them. It ended up in a good place - with Simonden @ the Four Quarters arcade. Even had a go on it when I went down there
Purity2016-08-21 20:44:38
5,332CR
Just curious - why did you originally want rid of the LCD to go with CGA?
It's medium-res so you don't really have scanlines, so it's probably nicer to view it on an LCD (via 1 converter) than on a 15kHz CRT with interlacing (via 2 converters).
jonhughes
1,156CR
I was offered this one too. I didn't go looking for it.
That's the thing I find, a lot of cabinets probably go by un-advertised. I would never have put a listing in the wanted section for NARC. Just decided it would be nice to add to the collection when I was offered it. Problem was I bought it without seeing it and in hind sight it was more work than I imagined, it was certainly uncared for but has come up reasonably nice. However, several modifications needed to be done - mainly power. It's not worth burning my house down for.
Initially, I was trying running this through an old 19" LCD. It just wasn't looking right. The viewing angles were all wrong and the screen size wasn't right. I just thought the game didn't transfer to LCD correctly. A CRT always looks authentic also. The screen size was bugging me a lot and I thought the adjustment levels on a CRT would give me more options and the authenticity.
Turned out it was a combination of the old monitor and the convertor being on the blink before finally imploding. I have a modern 24" I use for work and it won't fit the machine, otherwise I'd have been tempted to switch them over. When I tried the game on this it looks fantastic, so I'll be sticking with the LCD. It is an exceptionally good image and accepts the video directly with no need for that video convertor. I hope the one I ordered is similar - I got a bargain with similar resolution. Will see when it arrives.
jonhughes2016-08-21 22:39:09
