As said above,check the PSU voltages too and I'd unplug the power loom PSU side and check if the pins or crimps have ' blackened 'or if the wires themselves have become ' crispy '.The old similar Maygay PSU suffered from the wires losing conductivity in the 5cm PSU side, they'd be solid,no flexibility left. Check the Scorpion 4 to see if the battery has leaked and corroded the traces in that area. I'd also pop out the program card to make sure the pins are all aligned correctly, had it before where the corner pins have been bent out against the housing. Finally hope to God that the security chip hasn't died, that's terminal and reduces it to a parts board unless anybody has managed to hack it yet
Hopefully by unplugging everything and plugging it back in it'll remove some pin oxidisation and you'll be good to go.
Great machine btw loved it bitd with the flashing light on top.
Good luck.
