Core Grafx White Screen Help
Beaps
368CR
Picked up a Core Grafx thats only dispaying a white screen. Some say its not seeing the Hu Card thats inserted but the pins look great. I looked inside also and it looks brand new also.
Any ideas
Beaps2019-12-09 23:23:23
Beaps
368CR
I've only the one hu card and it was tested before I got it. Ive clean the card slot with contact cleaner so it looks mint. I did google online and some say it could be 6280, wram or 6270
robotech
823CR
ive only worked on one of these core grafx / cdrom unit sets
When i did a
rgb mod and cd drive recap for paul
Just some other stuff i would try
with the lid off the console and the card port disconnected
From the top lid
Check visually that the pins are sitting on the card contact points
Then allthough the ribbon cable should not move inside the case
Check ribbon cable connections / continuity from card slot to motherboard connections just incase someone has been inside it allready messing about and damaged anything
robotech2019-12-10 02:34:04
robotech
823CR
https://www.google.com/url?sa=t&source=web&rct=j&url=https://old.pinouts.ru/Game/CartridgePcEngine_pinout.shtml&ved=2ahUKEwiliLiizKvmAhU1URUIHRibBs8QFjAAegQIBBAB&usg=AOvVaw3Aodx1WR5MjpxVUx5hCJwt&cshid=1575998741912
Just found a pinout list for the cartridge slot looks like they all should be connected
Ace`
PlanB contributor #1
40 (100%)
4,040CR
I've got an original pce with the same issue, it has a bad hu6270. Other than taking one from another system they aren't available.
griffo83x
30 (100%)
746CR
Beaps said:
Does anyone here fancy a go at fixing it, I'm sure it's one of the surface mounted chips at fault.
Send it over mate i got a hammer
