The filter helps against rf pollution on the mains lines. They are usefull in the case of switch mode power supplies, altough those should already have a buildin filter if they are not chinese junk. I have a laptop power supply that produces so much interference that all my homeplugs lose connection with each other when it's plugged in. I added a line filter and the problem went away.
A line filter can also help against interference from other equipment like an electric drill or mixer. Without filter, you can sometimes see stripes in the picture, but again, normally the electric drill should have a filter to prevent this and the cabinet monitor chassis should have a filter as well to avoid such. Let's say, in an ideal world, an extra netfilter isn't needed.
