Cosmic Guerilla
paulcan69
945CR
Need your help guys, outta my comfort zone with AC powered cabs lol
Never worked as long as I had it...looked like a board fault (monitor comes on has power but game doesn't boot) so instantly tried to find another pcb, got one from Guddler (thanks bud) that we know is 100% with a DC mod and on his rig at home.
But with DC mod removed in my cab board is exactly the same as mine (grey screen and trying to boot/sync)
Isn't playing blind as you can coin up and nothing changes...no sound
I have 4.70v across any chip on the pcb, and the 3 led's which show that it has 12v....5v....and -5v are all lit up
Now is 4.70v too low in a AC cab?
I guess it might be??
But how can I up voltage with no switcher?
This cab is really clean and looks untouched almost like it hasn't ran since the 80's
Any ideas..?
This thread is for Guddler to show my videos and photo's
And for anyone else to kindly pitch in to get this lovely little cab up and running
Thanks in advance....
Pics and video
paulcan692014-01-06 21:49:32
paulcan69
945CR
P.S The video is me turning it on/off so you can see "something" on the screen.
Also adding a credit (note the click of the coin meter) just to show nothing changes...
Please help!!
Guddler asked for what AC voltages at the pcb...
Red wires
Purple wires
and orange wires
All had approx 10.5v AC at all of them?
It should be 8V, 10V and 12v
Confused.com LOL
Hate A/C!!!!
paulcan69
945CR
Someone said I need to check the voltages of the AC in connector whilst not plugged into the pcb
I was sticking the multimeter probes in the back of the molex connector
So tomorrow I will try to measure it unplugged from the pcb
4,058CR
Can anyone else help here? I'm at a bit of a loss here too! I'm pretty damn sure that I've had the PCB working at voltages down as low as 4.7v.
For the record, the board has 4116 RAMs on it and I asked Paul to measure the three voltages there. We get:
Pin 1. I have -5.1v
Pin 8. I have +11.95v
Pin 9. I have +4.66v
Now, sure that +4.66v is kinda low but I think still enough to get something from the board so I don't think it's our problem. Does anyone else know their way around these cabs? According to the schematics there's a reset switch. I don't know where it is, nor do i know exactly what will happen if it's not functioning but I wouldn't mind betting the board will be held in reset. I don't think it's the one that you can see in the top left of the video, I think that's a power interlock switch, but even if it were that one, the video shows that the board has been tried with the door closed so I guess we've covered that.
Something else I'm suspicious of...
That monitor looks mightily like a B/W picture and the board I sold at least is set up to output colour. I think the PCB needs modifying for B/W vs Colour, but again not entirely sure on that without digging out manuals and schematics. Now the board in the video isn't the one I sold. Is that the original board from the cab? Do you know if that's a colour modified board or a mono one??
Couple more things I guess.
If all else fails, is there anyone near Paul that is knowledgable and could have a nose at the cab?
paulcan69
945CR
The monitor is colour....
I feed it rgb via my test rig and it had a good colour picture
But I know what your saying, both cg pcb's look the same when you turn it on
paulcan69
945CR
And thanks Guddler for putting that info up, I would have struggled to find that info again
Ta fella
And I would be more that happy to sort out a "cash drink" and supply tea/beer if anyone could have a look
I'm fine around normal dc cabs but this is a melon scratcher
Your welcome to play on my other cabs too lol
4,058CR
OK, not that either then. Just looked a bit like it in the vid
Let's see if anyone else can suggest anything.
Something in the cab (i think) is preventing both of these boards from doing anything and I'm at a bit of a loss as to what without having a prod about and I'm about 4 hours or more drive away!
obcd
3,830CR
I answered in the other thread.
You might be able to check the datasheets of the cpu on the board and check it's reset line. Some boards keep the cpu in reset utill the supply reaches a predefined level.
Schematics of at least that power supply is what you need first.
