Couple Questions
aeroflott
A different league
16 (100%)
1,061CR
Couple of questions gents just to check I'm not going mad.
1. I want to bypass this Cherry door switch as its very stiff and I suspect knackered. To do this, am I right in saying I just splice together the two brown wires, and splice the back wire to the white wire?
2. Got an old cab with with no plug. The three wire colours are black, red and white. I'm assuming black is Neutral, red is Live and white is Earth?
Ta!
obcd
3,830CR
Looks more to me like brown and white connected and brown (not connected) and black (not connected)
Or maybe the other way around?
So you have switch between 2 4 6 and one between 1 3 5
Maybe, you can measure it. With some luck one of the switches still works in both, or at least in one position.
smarty
Ready Player One
1,305CR
1. When the switch is connected (either pushed in or pulled out in its locked position) the white wire will be connected to the left brown and the black wire to the right brown wire that has one loose. You can join them to bypass the switch. You could test the switch by using a multi meter in continuity (beep mode) with the cab power turned OFF, connect red and black probes to pins 2 & 6, when the switch is closed you could get a beep or 0.00 on your multi meter. Same for switch pins 1 & 5.
If this is the only interlock switch in the cab is would suspect the white & black cable would read 240Vac if you put a meter across them with the cab powered.
2. If it was a cab from the USA the black would be the Neutral and white the Live, in the UK I think you have it right but I would again be using my multi meter to buzz the cables, you should be able to find the earth easily if its connected to most metalwork within the cab, Live and Neutral may wire into a mains filter and be labelled. How about a photo of the power inlet ares within the cab?
smarty2016-09-10 08:11:48
niknak
Raffles the gentleman thug
172CR
the brown is on the common tab and the black white are connected to the normally open tabs. So yeah, do what you say.
If still unsure, - this if from memory, mileage may vary - trace the browns back, they should go to ground. The black and white will come from Live directly and go straight to a fuse after the switch.
I'm wrong. So so wrong
niknak2016-09-10 08:22:14
tin
673CR
For the cherry the leftmost two wires together and the rightmost two wires together. The diagram is on the switch (and http://www.res-rich.com/cherrycorp/epmd_cutaway_2x.gif)
Also I like how there are yellow boots on the wires for safety but none on the (normally closed) two spare terminals! Ouch!!
For the wiring colours I dunno. I'd be very surprised if it's UK as the blue/brown/green&yellow has been in use on stuff that plugs in (as opposed to the stuff you plug into) since the 70s.
tin2016-09-10 08:52:19
aeroflott
A different league
16 (100%)
1,061CR
This is really useful - thanks Smarty.
This is the Cosmic Guerilla cab I mentioned, so you'll get to see it tomorrow I suspect! I'll hunt for new switch - pretty sure I have one somewhere and replace this one.
aeroflott
A different league
16 (100%)
1,061CR
Thanks gents. I managed to test continuity on this switch and it is working OK. I've reconnected the brown wire - all is well on that front.
Next question regarding the wiring on this cab. The mains lead wires are coloured Red, Black and White.
My assumption looking at this was:
Red: Live
Black: Neutral
White: Ground
When I got the cab it was described as "not working" and the length of the wires as found within what was a crushed wall plug would suggest that this was how it was wired within that plug, or at least that's how it had been wired by someone previous to me (they were pulled from the terminals and the plug had been completely crushed by something and sitting inside the cab).
Here's a shot of the cable coming into the cab and connecting up to the power block:
As you can see the Grey mains cable comes in, and the Black and White wires connect to a switch located underneath the cab (which is the brown block bottom left of the pic). (From the switch, both wires go to the interlock switch mentioned before, and then back down to the fuses and onto the line filter).
But the Red wire that comes in, goes straight to a screw at the bottom of the Transformer and is connected to the middle spade of the line filter.
I'm very suspicious of this. Now correct me if I'm wrong, but every line filter I've seen has the middle spade there marked up as Ground? And connecting a live cable to a screw on the bottom of the transformer and then onto this middle spade can't be a good idea?
So on that one on the left, live is top, middle is ground, bottom is neutral?
So theorising here, did the previous owner wire the plug up wrong, putting the red cable on the live terminal of the wall plug, and in the process blew the line filter? All fuses are intact, and I can't see any burnt components on the board - in fact, everything is very clean.
So given all that, how should this be wired up into a wall plug (before I go ahead and replace the line filter and plug in) - do I assume that red should actually be used as Ground?
Here's a bigger pic of the whole setup:
aeroflott2016-09-10 15:03:25
aeroflott
A different league
16 (100%)
1,061CR
Right - case closed. Rewired the plug
Red - Ground/Earth
Black - Live
White - Neutral
Cab fires up. Got a board fault - I'll start another thread for that.
It seems German wiring protocol in the 70's/80's was red to ground/earth!
aeroflott
A different league
16 (100%)
1,061CR
Just to follow up on this. I found this image on a German language website:
The caption reads: A cable with old wire insulation has been extended with a new cable (and new wire colors).
You can see the "old" German wiring colours which used red as Ground coming out the wall.
