chomponooch
I have
three CPS 1.5 boards (1xPunisher, 2xWoF)
One of them is The Punisher (ETC 930422) (8bit, 32 pin
EPROMs) – Sticker on Eprom24 is PSE24.
Replaced EPROMs with proper ones programmed with
suicide free code. Modified the C board and Q-Sound boards. Replaced the 27C010
on the Q-Sound board with a 27C020 programmed with suicide free code and...
The
Punisher (when using orginal The Punisher sound board) boots with "ram
err" when using Warrior of Fate sound board to run The Punisher - game
works, graphic is ok but there is no sound (q-sound error on setup screen)
Tried to
change Kabuki to Z80 - nothing.
Tried to
replace the 8 1Mb EPROMs with 2 4Mb 16 bit EPROMs with the 16 bit version of
the Phoenix
code - nothing.
I double
checked my revive fix, and tried use another Q-sound board and another main board. Game runs and plays
fine but no sound, I get a buzz from the speaker
On all them (CPS 1,5 boards) the effect of the modification is the same. At best - the
games run without sound.
I think
that the game runs means that the suicide fix worked.
The game
will not run if the Q-sound Kabuki fix is not done correctly.
Has anybody had a similar problem with CPS 1.5 boards?
Thank you for any help.
The
Tried to
Tried to
the Phoenix
code - nothing.
I double
I think
The game
